Problems under CentOS
Postby Traveler » Wed Sep 25, 2013 9:43 pm
I've successfully installed TBS5220 under my Centos 6.4 PC (x64), but I am experiencing a lot of issues with this tuner. Issue is that after some time I get just this message in dmesg:
TurboSight TBS 5220 Frontend:
tbs5220fe - running software failed
tbs5220fe - software version is 1.0.0.0
tbs5220fe - Successfully Initialized
And of course MuMuDVB stop to stream channels, and only reboot help me to solve this issue. Also I tryed to run MuMuDVB without reboot, and MuMuDVB have signal but simply not stream channels, all what is needed is to reboot PC.
This is first TBS product with which I am having issues, can anybody help or suggest something?
P.S: Tuner is each time properly initialized
usb 1-5.2: new high speed USB device number 4 using ehci_hcd
usb 1-5.2: New USB device found, idVendor=734c, idProduct=5220
usb 1-5.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-5.2: Product: TBS 5220
usb 1-5.2: Manufacturer: TBS-Tech
usb 1-5.2: configuration #1 chosen from 1 choice
dvb-usb: found a 'TBS 5220 USB2.0' in cold state, will try to load a firmware
usb 1-5.2: firmware: requesting dvb-usb-tbsqbox-id5220.fw
dvb-usb: downloading firmware from file 'dvb-usb-tbsqbox-id5220.fw'
tbs5220: start downloading TBS5220 firmware
dvb-usb: found a 'TBS 5220 USB2.0' in warm state.
dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
DVB: registering new adapter (TBS 5220 USB2.0)
dvb-usb: MAC address: ff:ff:ff:ff:ff:ff
tbs5220: Attached TBS5220FE!
DVB: registering adapter 0 frontend 0 (TurboSight TBS 5220 DVBT/T2 frontend)...
input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:1d.7/usb1/1-5/1-5.2/input/input6
dvb-usb: schedule remote query interval to 150 msecs.
dvb-usb: TBS 5220 USB2.0 successfully initialized and connected.
Traveler
Re: Problems under CentOS
Postby crazycat » Thu Sep 26, 2013 4:12 am
maybe powering issues ? connected to desktop PC ?
