TBS6925 DVBS2 GoldCode support now............
Postby steven » Tue Mar 05, 2013 2:35 pm
Hi All
Good news that TBS6925 can lock DVBS2 GoldCode Transponder now.Here is the new driver and
TBSRecorder.If in your place has GoldCode Transponder,Please have a try with the new driver
and new tool,And send your test report here.
SetGoldCode
After enter the GoldCode, Please press set button to send the GoldCode to TBS6925,Then Press Lock TP. :)
If all is ok,We will release it . :)
New test driver:
https://hotfile.com/dl/197299536/a136a44/TBS6925_V.0.1.18_20130307.zip.html
New TBSRecorder:
https://hotfile.com/dl/197038180/01a10cd/Setup_TBS6925-TSRecorder(3.0.0.7).zip.html
Kind Regarsd
Re: TBS6925 DVBS2 GoldCode support now............
Postby DVB » Wed Mar 06, 2013 5:58 am
When trying to click "Set" got message
"don't support this interface".
Drivers 1.0.1.18 are installed (Win7 x64).
And now you're watching 8K:
KKKKKKKK
DVB
Postby steven » Thu Mar 07, 2013 2:20 pm
Hi DVB
Thank you very much for your test report. In your place can you receive the DVBS2 GoldCode signal??
We will have a check with this.And give you a reply later. :)
Postby steven » Thu Mar 07, 2013 5:11 pm
Hi DVB
Please have a try with this new one:
Postby DVB » Fri Mar 08, 2013 6:55 am
Now works (Successful set the GoldCode!)
By saying GoldCode You mean PLS (Physical Layer Scrambling) with Gold mode? There are aso two other modes (Root and Combo) and to get this complete - there should be also way to select PLS type (Root, Gold or Combo). Now it looks like it support only PLS in Gold type (no Root and no Combo modes).
Root type can be seen at 13°E (italian transmissions from 11,432V and 12,539H), RootCode is "8" for them, at this moment both doesn't work (code set, but no signal).
Details: http://www.s2licensing.com/assets/docum ... andard.pdf (page 30), THX crazycat ;)
PS: For other users: be aware that if You set GoldCode to other value than "0" - all DVB-S2 signals won't be receiverable (only that one with GoldCode that You selected will work and all other that use the same code). You need to set GoldCode back to "0" to lock normal DVB-S2 transmissions.
PS: Would be possible to publish 1.0.1.18 drivers also in "fast" version (it is now "slow" release, I mean discussion from here: viewtopic.php?f=25&t=1378&start=10 ). It would be nice (if it is possible) if You could release two driver versions - 1.0.1.18 slow and 1.0.1.18 fast ;)
KKKKKKKK
DVB
Postby steven » Fri Mar 08, 2013 9:44 am
Hi DVB
The GoldCode is the PLS (Physical Layer Scrambling) with Gold mode.
It is just a DVBS2 parameters,as you can see here:
http://en.kingofsat.net/find.php?questi ... Submit=Zap
PLS: Gold+121212
Kosio have checked this ,which can be locked with TBS6925. :D
Yea,Forget to say this,but when you exit TBSRecorder ,it will auto set the GoldCode to "0",So next time normal use is ok. :)
Postby DVB » Fri Mar 08, 2013 10:28 am
Thanks for confirming, great news that now it is available also by drivers :D Any chances for Root & Combo mode beside Gold in future? ;) Combo is probably not used at this moment, but Root is pretty popular in Europe ;) And are there any chances for faster drivers beside slower version? ;)
KKKKKKKK
DVB
Postby steven » Fri Mar 08, 2013 11:43 am
Hi DVB
We will have more check with Root & Combo .
And maybe next version driver we will release two version ,fast one and slow one. :D
kind Regards
Postby Derrick » Mon Mar 11, 2013 1:18 am
..hmm, this has been implemented long time by @crazycat in his Crazsyscan. The TBS tools are rather useless in my opinion.
Derrick
Postby DVB » Mon Mar 11, 2013 1:33 am
Of course PLS is available in CrazyScan but thanks to adding this into driver in can be easier accessible by authors of DVB apps. The only way to use PLS at this moment is to do some low level magic or use StreamReader.dll from crazycat. After adding PLS control into driver any DVB app will be able to select PLS without StreamReader.dll or device hacking... Now only add Root & Combo, update SDK and any DVB app will able to support PLS :D Definetely step in good direction :D
KKKKKKKK
DVB
