Disceq problem
Disceq problem
Postby ssenyer » Tue Dec 21, 2010 5:16 pm
Recently i bought a 6981. I have 3 satellites in one cable.
AA--->42E Turksat
AB--->13E Hotbird
BA--->7E Eutelsat W3
My problem is here: i can not go from one satellite to other. i mean disceq not working for both turners. I have no idea how can i fix it. I read a thread related with this problem but i dont have enough knowledge for understand what they are talking about :) Can someone help me please. If u need any info please let me know.
Here is the thread: http://www.buydvb.net/forum/viewtopic.php?f=2&t=39&start=10#p213
Thanks.
Edit: it is not a software problem cause i tried 3 or 4 different softwares and disceq didnt work with any software.
ssenyer
Re: Disceq problem
Postby ssenyer » Wed Dec 22, 2010 7:07 am
OK,
i tried with dvb dream and those uncommitted hex codes works for me. Now i can switch between satellites.
Now another problem: how can i able to do this with mediaportal?
Any idea?
ssenyer
Re: Disceq problem
Postby cody » Fri Dec 24, 2010 5:25 am
hi, if you now know the correct commands (hex values) that instructs your disceq switch to change the satellite then you can use them with any DVB application - i mean all DVB applications i can think of, provide way for manually input disceq commands for the switch. i don't know specifics for mediaportal though. however, i'm sure they implemented proper disceq support for 6980 some time ago and that should work with 6981 too.
Re: Disceq problem
Postby ssenyer » Mon Dec 27, 2010 5:21 pm
Hi Cody,
Thanks for your reply. There is something strange with my disceq. As i post earlier my disceq worked with uncommitted commands. Then i format and reinstall my windows OS and tried again with same hex codes. But it did not work with those codes even it worked before. Then i tried with committed codes. Also those codes didnt work. I have multiswitch (terminal) for 32 users. here is the link http://www.next.com.tr/default.asp?git=9&urun=240.
For now i m searching for correct hex codes for my multiswitch.
ssenyer
Re: Disceq problem
Postby cody » Tue Dec 28, 2010 4:43 am
hi, after you reinstall your OS, did you copy "bda.dev" file from your installation CD for TBS 6981 to "Devices" folder under your DVBDream installation folder?
Re: Disceq problem
Postby ssenyer » Tue Dec 28, 2010 3:43 pm
No, i m using DVBLink TV source software.
ssenyer
Re: Disceq problem
Postby cody » Wed Jan 05, 2011 5:52 am
ssenyer Wrote:Hi,
hi, maybe your DVBLink version is old without TBS 6981 support. you can try the one on our website:
http://www.tbsdtv.com/download/common/D ... BS_v32.zip
it's the latest version with discount for TBS users.
Re: Disceq problem
Postby ssenyer » Thu Jan 13, 2011 4:52 pm
i'm not using DVBLink anymore since i m now able to use Mediaportal with MDAPI.
ssenyer Wrote: I have 3 satellites in one cable.
AA--->42E Turksat
AB--->13E Hotbird
But i still have disceq problems with MP. After my last post i reinstalled my OS (win7 x86) and DVBDream works really great with my card even i dont use those hex codes. But in MP my LNB1 dont work...While using MP, turner is not locking to LNB1. It is really weird since i can switch between LNB2 to LNB3 or vice versa without any problem. Only problem is LNB 1 now. when i stop MP tv server and start DVBDream to change to LNB1 it works well..
cody Wrote: i don't know specifics for mediaportal though. however, i'm sure they implemented proper disceq support for 6980 some time ago and that should work with 6981 too.
Depending on my problem, unfortunately it is not work for 6981:(
Here is the link for thread at Mp forums for 6980.
http://forum.team-mediaportal.com/tv-cards-333/tbs6980-dvb-s-s2-tuning-issue-diseqc-77808/
Any advice?
EDIT: i also upgraded my driver to 2.0.0.14, it was 2.0.0.8 when this thread start.Also my OS was win7 X64 but now Win7 X86
ssenyer
Re: Disceq problem
Postby cody » Fri Jan 14, 2011 1:54 am
exactly, this thread is about when support for 6980 was added to MP and you can see that the last post there confirms it's OK:
My TBS6980 runs fine in Mediaportal and also DiseqC functions fine there.
ssenyer Wrote:Any advice?
MP is third party and open-source application, we have SDK:
http://www.tbsdtv.com/download/common/TBSDTV-SDK(1007).rar
where every developer, including MP ones, can see how Diseqc is controlled - i mean if DVBDream works then it's MP problem.
Re: Disceq problem
Postby ssenyer » Fri Jan 14, 2011 3:23 am
Thank you Cody,
I ll try to get some help from MP forum.
ssenyer
