BSOD with 8922
BSOD with 8922
Postby riccume » Mon Sep 05, 2011 5:33 am
I'm having the same BSOD problems with the 8922 that I used to have with the 8921 - at least once a week the HTPC freezes and the BSOD comes up, no apparent reason. I took a look at the reports and in all of them the Bug Check String is "BAD_POOL_CALLER" and among the drivers found in the stack I always see tbs8922.sys (the others being halmacpi.dll, ks.sys, ntkrnkpa.exe, by Microsoft). I'm using the latest driver (v1.0.0.7 according to the text, but the downloaded file is called TBS8922Driver_V1.0.0.6.rar...); Windows 7 Professional 32bit, Windows Media Center. Will you be able to provide an updated driver? Thanks.
riccume
Re: BSOD with 8922
Postby steven » Mon Sep 05, 2011 9:49 am
You mean that 8921 have BSOD in your computer too?and would you mind just uninstall TBS8922VHID and then have a test.
Re: BSOD with 8922
Postby riccume » Tue Sep 06, 2011 1:54 am
Hi Steven. The 8921 had BSOD problems before I removed it from my system; I substituted it with the 8922 and now I have problems with that one too. I didn't have any such problem with my previous DVB-S card (Compro VideoMate S350).
Do you want me to uninstall with 8922? I'd be left without satellite TV at that point.
riccume
Re: BSOD with 8922
Postby steven » Tue Sep 06, 2011 3:09 pm
Hi riccume
Would you mind tell us that when BSOD come out,do you have done something?and do you have another HTPC,if you have ,
can you use the other one have a test.
Re: BSOD with 8922
Postby riccume » Wed Sep 07, 2011 5:56 am
Unfortunately I haven't noticed any triggering event - most of the times when the BSOD happens the HTPC is simply on; sometimes it is recording; sometimes I am watching a video. And no I only have one HTPC, sorry.
riccume
Re: BSOD with 8922
Postby steven » Wed Sep 07, 2011 5:01 pm
Hi riccume
Is your HTPC have another PCI slot,would you mind use the other slot to have a test.
Re: BSOD with 8922
Postby riccume » Fri Sep 09, 2011 5:56 am
OK, I'll switch cards (I have another slot used by a DVB-T card) over the weekend and have a go.
riccume
