TBS8921 Blindscan.exe v3.0.0.2
Postby Derrick » Thu Apr 28, 2011 5:03 pm
Until reading @Steven's post (https://shop.tbsdtv.com/forum/viewtopic.php?f=23&t=386&p=1999#p1999) I wasn't aware that an update of the blindscan tool has been released. Now diseqc seems to be supported.
But what a disappointment. The tool won't finish any scan and has to be aborted manually without results. After a 2nd try a diseqc error is reported. Finally, closing the tool will cause a BSOD. What a crap!! :evil:
Derrick
Re: TBS8921 Blindscan.exe v3.0.0.2
Postby steven » Fri Apr 29, 2011 10:39 am
Hi Derrick
I am so sorry about this problem,I have not mentioned that this tool must use the latest driver 1.0.0.4 ,do you have installed the latest driver?
Postby Derrick » Fri Apr 29, 2011 6:57 pm
with 1.0.0.4 the tool is stable. But that's all what I can say. 22khz and diseqc are not working.
Is it possible to add the debug feature to the new driver(s)?
btw.
none of the other performance problems have been solved yet..
Derrick
Postby steven » Sun May 01, 2011 8:54 am
Derrick Wrote:with 1.0.0.4 the tool is stable. But that's all what I can say. 22khz and diseqc are not working.
btw.
Hi derrick
About the diseqc,It is the driver problem we have updated tbs8921's driver,just for your test,will be published later.
here is the tbs8921 x86 xp driver:http://hotfile.com/dl/116357255/f17f3fb/TBS8921_Driver_x86_1.0.0.5.rar.html
Postby Derrick » Sun May 01, 2011 2:27 pm
1.0.0.5 doesn't work either. Still no high band (22khz) and no diseqc..
Derrick
Postby steven » Sun May 01, 2011 9:15 pm
Derrick Wrote:1.0.0.5 doesn't work either. Still no high band (22khz) and no diseqc..
Thanks for your test report.I will check it later.
Postby Geezerjem » Tue May 10, 2011 4:17 am
I made my first post about the blindscan tool not working on the 13th of January this year. Now four months later I have tried 3.0.0.2 and although it's better i.e. gives the correct frequencies when not using the 22KHz High Band it is still woefully inadequate. Even when it found a BIG signal on 37.5W at 11683 V SR 8700 and DVB-S2 FEC 3/4, the .INI file generated was:
;file generated by TBS Card - http://www.tbsdtv.com
[SATTYPE]
1=TBS
2=TBS
[DVB]
0=1
1=11683,V,8700
It doesn't contain the S2 information, or the FEC.
:-( and :( again.
I state again that the reason I bought this card over others was the well publicised BlindScan facility. It still does not work. Please sort it out.
By the way, it sure looks like the hardware side of the company has a healthy budget as there have been several new cards relased since January. Cody, I'm sorry the software department is not budgeted to the same level. Get your boss to explain why please, because I (and others) would like an explanation from them as to why promised things aren't happening.
Jem.
45W to 42E
Win7 32 Bit
UK :-)
Geezerjem
Postby steven » Tue May 10, 2011 9:40 am
Geezerjem Wrote:I made my first post about the blindscan tool not working on the 13th of January this year. Now four months later I have tried 3.0.0.2 and although it's better i.e. gives the correct frequencies when not using the 22KHz High Band it is still woefully inadequate. Even when it found a BIG signal on 37.5W at 11683 V SR 8700 and DVB-S2 FEC 3/4, the .INI file generated was:
[SATTYPE]
1=TBS
2=TBS
[DVB]
0=1
1=11683,V,8700
:-( and :( again.
Hi Geezerjem
New driver will be released soon,sorry for the problem you have met ,
Thanks.
