Matrix Failure
Matrix Failure
Postby Dippo » Mon Apr 07, 2014 9:55 pm
After just over a week of happily using my new Matrix, I came down this morning to find it not working. Nothing comes up on the TV after a reboot and it is not pingable from my laptop. I thought I would try reloading the OS (MatrixTV latest version) however it sits on the Jumping to OS image message for 5+ minutes, then onto Loading U-boot where it will stay indefinately.
I have tried the reset button also, but no difference.
Is there anything else I can try first before I pack it back into the box and return it to the distributer ?
Thanks in advance for any advice
Dippo
Re: Matrix Failure
Postby steven » Thu Apr 10, 2014 5:02 pm
Hi Dippo
It is like your Matrix is broken ,You can contact our support to replace a new one. :)
Re: Matrix Failure
Postby Dippo » Sun Apr 13, 2014 6:05 pm
Thanks Steven, have returned to the distributer now as it was within my 30 period and eagerly await my new one arriving...
Dippo
Return to General discussion
