Q-Box won't work
Q-Box won't work
Postby seeman » Tue Feb 15, 2011 6:16 pm
Hello, hope to find some help about the problem.
Got a new Q-Box (S/N TBSQ190400283), should be used on PC Win7-64 Enterprise.
But don't work, because Q-Box is recognized as "unknown device", stopped by failure.
All possible driver versions, all possible installation procedures are tested,
every time same result in device manager:
"unknown device, device stopped, because device reporting errors,
failure no. 43"
Built in DVB Cards, e.g. TBS 8920, 6981 on same computer works fine.
Is there any solution about?
Thanks in advance.
Best regards
seeman
seeman
Re: Q-Box won't work
Postby cody » Wed Feb 16, 2011 7:16 am
hello, did you send us mail to the support e-mail addresses? i'm asking, because i already answered via e-mail about similar issue and i'm just wondering if you're the same customer that i already answered or you're another i need to give you assistance here too. thanks!
Postby seeman » Thu Mar 03, 2011 7:22 pm
Hello Cody,
sorry for late answer, having a car accident, but now OK again.
No, I'm just the other one and a very new customer.
So you get my support inquiry via support mail.
Hoping to find your great assistance.
Thanks in advance.
Best regards
seeman
seeman
