tbs 6903 can not work in DisEQc 1.1?
Postby liang747 » Mon Aug 01, 2016 10:20 am
hello i buy a tbs 6903 tv card,but it can not work in DiseQC1.1,
it do not spoort diseqc1.1?ths
liang747
Re: tbs 6903 can not work in DisEQc 1.1?
Postby steven » Mon Aug 01, 2016 4:05 pm
Which application you used with 6903 ? linux or windows ? as our card driver in linux and window both have the Diseqc interface so
just check whether the application added support
Postby liang747 » Tue Aug 02, 2016 5:55 pm
i use windows10 64bit card driver is 1.0.0.1,so i can use the DiseQC1.1 in EBSbillscan,but it can work in TransEdit and Dvbviewer,it only have single in LNB1.
Ths
liang747
Postby duane01098 » Tue Aug 02, 2016 6:49 pm
Hi liang, I have the same issue with Dvbviewer and Tbsviewer using the tbs 6902 card. Diseqc commands don't work. I downloaded the trial version of Dvbdream 2.81 and the diseqc commands worked fine. This might be worth a try for you to see if diseqc commands are working with your card. I don't know what EBSbillscan is......maybe there is an update available....Duane
duane01098
Postby liang747 » Tue Aug 02, 2016 10:35 pm
hi
duane01098
i know tbs 6903 can work in dvbdream with DiseQC1.1?,but i like dvbviewer and TransEdit,EBSbillscan is EBSpro my English is not good sorry.
liang747
Postby crazycat » Tue Aug 02, 2016 11:26 pm
Ask DVBViewer/Transedit authors about DiseqC support.
Postby satesco » Wed Aug 03, 2016 12:47 am
liang747 Wrote:hi
duane01098
Here's how to configure TransEdit and DVBViewer for Diseqc 1.1 .In the example below I chose lnb 7 for Astra 3B from 23.5 E of 16 LNBs for a toroidala dish.
Everything works fine if set correctly each lnb in TransEdit and than check Channel Editor .
satesco
Postby liang747 » Wed Aug 03, 2016 7:39 am
hi
satesco
can you send me the TransEdit V.4.1.1.0? Email:serlimon@163.com
i think i use V4.0.1.0 is not support DiseQC2.x,and what Switch do you use?
THANK YOU
liang747
Postby satesco » Wed Aug 03, 2016 5:44 pm
Hi liang747,
I sent the requested version to your email. I hope to help you, but I have to add that I've worked with previous versions of TransEdit and had no problems with diseqc 1.1. I think more important than the version used,is to properly configure the switch 1.1 in TransEdit! With EMP-Centauri switch 17in/1out 1.1&1,I haven't had problems since 2008 when I use it.
Regards
satesco
Postby liang747 » Fri Aug 05, 2016 7:36 am
hi satesco
i uesd ransEdit V.4.1.1.0 but it can not work “Analyze”?
liang747
