TBS6983 T2-MI
TBS6983 T2-MI
Postby mkotov » Fri Jul 29, 2016 7:20 pm
Hello!
I need receive multistream T2-MI stream from dvb-s2.
Is the TBS6983 have support t2-mi? Our distributor, the dvbstore.ru, says that old card - the 6925 support it, but they not have information about 6983.
Thanks.
mkotov
Re: TBS6983 T2-MI
Postby crazycat » Sat Jul 30, 2016 2:39 am
T2-MI not related to dvb-s2 card capabilities.
If you want receive russian T2-MI transponders - yoy can use any dvb-s2 card + some software capable t2-mi decapsulate ( for example free open-source astra-sm or astra 5.xx with subscribition, this for streaming with linux).
Re: TBS6983 T2-MI
Postby espaun206 » Thu Jun 04, 2020 10:17 am
crazycat Wrote:T2-MI not related to dvb-s2 card capabilities.
I'm testing with a tbs5520se,
and SmartDVB program and it doesn't work, it doesn't encapsulate the channel does not lower the PLP id
that you have to use a TBS with ACM, VCM, Multi Input Stream???
espaun206
