Cant upgrade my tbs 2603(Solved)
Postby snutteb » Tue Jul 26, 2016 11:45 pm
Hi have problem upgrading i have downloaded from your support page, unrar it to update.tar.bz2 try to upload to device get failed pls select the right file.
Any solution pls??? or i have to replace unit
snutteb
Re: Cant upgrade my tbs 2603
Postby snutteb » Tue Jul 26, 2016 11:59 pm
solved it, dont use firefox use explorer
snutteb
