TBS5281 with raspberry pi 3 ...
Postby gkar » Mon Jul 18, 2016 6:01 pm
Hi everybody,
My question is maybe simple but ... is it supposed to work ? because i donwload lastest drivers (on an raspian system (debian for raspberry pi) i can't compile them ... is it normal ?
./v4l/tbs-x86_r3.sh
TBS drivers configured for x86_r3 platform.
root@gkar-pi3:/home/pi/Downloads/tbs# make
make -C /home/pi/Downloads/tbs/v4l
make[1]: Entering directory '/home/pi/Downloads/tbs/v4l'
creating symbolic links...
make -C firmware prep
make[2]: Entering directory '/home/pi/Downloads/tbs/v4l/firmware'
make[2]: Leaving directory '/home/pi/Downloads/tbs/v4l/firmware'
make -C firmware
make[2]: Nothing to be done for 'default'.
Kernel build directory is /lib/modules/4.4.13-v7+/build
make -C /lib/modules/4.4.13-v7+/build SUBDIRS=/home/pi/Downloads/tbs/v4l  modules
make[2]: Entering directory '/usr/src/linux-headers-4.4.13-v7+'
  LD [M]  /home/pi/Downloads/tbs/v4l/tbs6980fe.o
ld: /home/pi/Downloads/tbs/v4l/tbs6980fe_driver.o: Relocations in generic ELF (EM: 3)
/home/pi/Downloads/tbs/v4l/tbs6980fe_driver.o: error adding symbols: File in wrong format
scripts/Makefile.build:391: recipe for target '/home/pi/Downloads/tbs/v4l/tbs6980fe.o' failed
make[3]: *** [/home/pi/Downloads/tbs/v4l/tbs6980fe.o] Error 1
Makefile:1385: recipe for target '_module_/home/pi/Downloads/tbs/v4l' failed
make[2]: *** [_module_/home/pi/Downloads/tbs/v4l] Error 2
make[2]: Leaving directory '/usr/src/linux-headers-4.4.13-v7+'
make[1]: Leaving directory '/home/pi/Downloads/tbs/v4l'
make: *** [all] Error 2
gkar
Re: TBS5281 with raspberry pi 3 ...
Postby crazycat » Tue Jul 19, 2016 1:01 am
Linux-tbs-drivers only for x86/x86_64.
Use open-source drivers from my media_build. But 5281 support need testing.
Postby gkar » Tue Jul 19, 2016 2:34 am
I've succeeded to compile your driver ... and install it ... some warning appeared
cd <your kernel dir>
WARNING: This is the V4L/DVB backport tree, with experimental drivers
    backported to run on legacy kernels from the development tree at:
      http://git.linuxtv.org/media-tree.git.
    It is generally safe to use it for testing a new driver or
    feature, but its usage on production environments is risky.
    Don't use it in production. You've been warned.
during compiling some module
  CC [M]  /home/pi/Downloads/tbs3/media_build/v4l/stv6120.o
/home/pi/Downloads/tbs3/media_build/v4l/stv6120.c: In function 'init_regs':
/home/pi/Downloads/tbs3/media_build/v4l/stv6120.c:195:6: warning: unused variable 'bbmode' [-Wunused-variable]
  u32 bbmode = 0xffffffff;
/home/pi/Downloads/tbs3/media_build/v4l/stv6120.c:194:6: warning: unused variable 'agcset' [-Wunused-variable]
  u32 agcset = 0xffffffff;
/home/pi/Downloads/tbs3/media_build/v4l/stv6120.c:193:6: warning: unused variable 'agcref' [-Wunused-variable]
  u32 agcref = 2;
/home/pi/Downloads/tbs3/media_build/v4l/stv6120.c:192:6: warning: unused variable 'agcmode' [-Wunused-variable]
  u32 agcmode = 0;
/home/pi/Downloads/tbs3/media_build/v4l/stv6120.c:191:6: warning: unused variable 'clkdiv' [-Wunused-variable]
  u32 clkdiv = 0;
/home/pi/Downloads/tbs3/media_build/v4l/stv6120.c: In function 'set_lof':
/home/pi/Downloads/tbs3/media_build/v4l/stv6120.c:324:6: warning: unused variable 'freq' [-Wunused-variable]
  u32 freq = Frequency;
/home/pi/Downloads/tbs3/media_build/v4l/stv6120.c:322:10: warning: unused variable 'tmp' [-Wunused-variable]
  u8 Icp, tmp;
/home/pi/Downloads/tbs3/media_build/v4l/stv6120.c:321:13: warning: unused variable 'psel' [-Wunused-variable]
  u32 p = 1, psel = 0, fvco, div, frac;
/home/pi/Downloads/tbs3/media_build/v4l/stv6120.c:321:6: warning: unused variable 'p' [-Wunused-variable]
/home/pi/Downloads/tbs3/media_build/v4l/stv6120.c: In function 'stv6120_attach':
/home/pi/Downloads/tbs3/media_build/v4l/stv6120.c:547:6: warning: unused variable 'stat' [-Wunused-variable]
  int stat = 0;
/home/pi/Downloads/tbs3/media_build/v4l/stv6120.c: At top level:
/home/pi/Downloads/tbs3/media_build/v4l/stv6120.c:145:12: warning: 'read_regs' defined but not used [-Wunused-function]
 static int read_regs(struct stv *state, u8 reg, u8 *val, int len)
/home/pi/Downloads/tbs3/media_build/v4l/stv6120.c:445:12: warning: 'get_frequency' defined but not used [-Wunused-function]
 static int get_frequency(struct dvb_frontend *fe, u32 *frequency)
/home/pi/Downloads/tbs3/media_build/v4l/stv6120.c:451:12: warning: 'AGC_Gain' defined but not used [-Wunused-variable]
 static u32 AGC_Gain[] = {
/home/pi/Downloads/tbs3/media_build/v4l/stv6120.c:484:12: warning: 'get_rf_strength' defined but not used [-Wunused-function]
 static int get_rf_strength(struct dvb_frontend *fe, u16 *st)
/home/pi/Downloads/tbs3/media_build/v4l/stv6120.c:502:12: warning: 'get_if' defined but not used [-Wunused-function]
 static int get_if(struct dvb_frontend *fe, u32 *frequency)
/home/pi/Downloads/tbs3/media_build/v4l/stv6120.c:508:12: warning: 'get_bandwidth' defined but not used [-Wunused-function]
 static int get_bandwidth(struct dvb_frontend *fe, u32 *bandwidth)
  CC [M]  /home/pi/Downloads/tbs3/media_build/v4l/r848.o
/home/pi/Downloads/tbs3/media_build/v4l/r848.c: In function 'R848_SysFreq_Sel':
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_DVB_T_6M' not handled in switch [-Wswitch]
     switch(R848_Standard) {
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_DVB_T_7M' not handled in switch [-Wswitch]
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_DVB_T_8M' not handled in switch [-Wswitch]
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_DVB_C_8M' not handled in switch [-Wswitch]
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_DVB_C_6M' not handled in switch [-Wswitch]
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_J83B' not handled in switch [-Wswitch]
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_ISDB_T' not handled in switch [-Wswitch]
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_ISDB_T_4570' not handled in switch [-Wswitch]
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_DTMB_4570' not handled in switch [-Wswitch]
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_DTMB_6000' not handled in switch [-Wswitch]
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_DTMB_6M_BW_IF_5M' not handled in switch [-Wswitch]
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_DTMB_6M_BW_IF_4500' not handled in switch [-Wswitch]
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_ATSC' not handled in switch [-Wswitch]
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_DVB_S' not handled in switch [-Wswitch]
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_DVB_T_6M_IF_5M' not handled in switch [-Wswitch]
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_DVB_T_7M_IF_5M' not handled in switch [-Wswitch]
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_DVB_T_8M_IF_5M' not handled in switch [-Wswitch]
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_DVB_C_8M_IF_5M' not handled in switch [-Wswitch]
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_DVB_C_6M_IF_5M' not handled in switch [-Wswitch]
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_J83B_IF_5M' not handled in switch [-Wswitch]
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_ISDB_T_IF_5M' not handled in switch [-Wswitch]
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_DTMB_IF_5M' not handled in switch [-Wswitch]
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_ATSC_IF_5M' not handled in switch [-Wswitch]
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_FM' not handled in switch [-Wswitch]
/home/pi/Downloads/tbs3/media_build/v4l/r848.c:2796:5: warning: enumeration value 'R848_STD_SIZE' not handled in switch [-Wswitch]
gkar
Postby gkar » Tue Jul 19, 2016 2:38 am
and also
  CC [M]  /home/pi/Downloads/tbs3/media_build/v4l/mxl5xx.o
/home/pi/Downloads/tbs3/media_build/v4l/mxl5xx.c: In function 'config_ts':
/home/pi/Downloads/tbs3/media_build/v4l/mxl5xx.c:984:18: warning: unused variable 'mxl561_xpt_ts_valid' [-Wunused-variable]
  MXL_REG_FIELD_T mxl561_xpt_ts_valid[MXL_HYDRA_DEMOD_ID_6] = {
/home/pi/Downloads/tbs3/media_build/v4l/mxl5xx.c:980:18: warning: unused variable 'mxl561_xpt_ts_sync' [-Wunused-variable]
  MXL_REG_FIELD_T mxl561_xpt_ts_sync[MXL_HYDRA_DEMOD_ID_6] = {
/home/pi/Downloads/tbs3/media_build/v4l/mxl5xx.c: In function 'load_fw':
/home/pi/Downloads/tbs3/media_build/v4l/mxl5xx.c:1161:44: warning: passing argument 3 of 'firmware_download' discards 'const' qualifier from pointer target type
  stat = firmware_download(state, fw->size, fw->data);
/home/pi/Downloads/tbs3/media_build/v4l/mxl5xx.c:768:12: note: expected 'u8 *' but argument is of type 'const u8 * const'
 static int firmware_download(struct mxl *state, u32 mbinBufferSize,
/home/pi/Downloads/tbs3/media_build/v4l/mxl5xx.c:1149:6: warning: unused variable 'buf' [-Wunused-variable]
  u8 *buf;
/home/pi/Downloads/tbs3/media_build/v4l/mxl5xx.c:1147:21: warning: unused variable 'cfg' [-Wunused-variable]
  struct mxl5xx_cfg *cfg = state->base->cfg;
/home/pi/Downloads/tbs3/media_build/v4l/mxl5xx.c: In function 'probe':
/home/pi/Downloads/tbs3/media_build/v4l/mxl5xx.c:1218:28: warning: unused variable 'mpegInterfaceCfg' [-Wunused-variable]
  MXL_HYDRA_MPEGOUT_PARAM_T mpegInterfaceCfg;
/home/pi/Downloads/tbs3/media_build/v4l/mxl5xx.c:1217:18: warning: unused variable 'j' [-Wunused-variable]
  int fw, status, j;
/home/pi/Downloads/tbs3/media_build/v4l/mxl5xx.c: At top level:
/home/pi/Downloads/tbs3/media_build/v4l/mxl5xx.c:154:12: warning: 'write_register_block' defined but not used [-Wunused-function]
 static int write_register_block(struct mxl *state, u32 reg, u32 size, u8 *data)
/home/pi/Downloads/tbs3/media_build/v4l/mxl5xx.c:223:12: warning: 'read_register_block' defined but not used [-Wunused-function]
 static int read_register_block(struct mxl *state, u32 reg, u32 size, u8 *data)
/home/pi/Downloads/tbs3/media_build/v4l/mxl5xx.c:278:13: warning: 'extract_from_mnemonic' defined but not used [-Wunused-function]
 static void extract_from_mnemonic(u32 regAddr, u8 lsbPos, u8 width,
/home/pi/Downloads/tbs3/media_build/v4l/mxl5xx.c:921:12: warning: 'config_ts' defined but not used [-Wunused-function]
 static int config_ts(struct mxl *state, MXL_HYDRA_DEMOD_ID_E demodId, MXL_HYDRA_MPEGOUT_PARAM_T *mpegOutParamPtr)
/home/pi/Downloads/tbs3/media_build/v4l/mxl5xx.c:1109:12: warning: 'config_mux' defined but not used [-Wunused-function]
 static int config_mux(struct mxl *state)
but after a reboot i only have this in my dmesg ...
[lun. juil. 18 20:21:30 2016] usb 1-1.5: new high-speed USB device number 5 using dwc_otg
[lun. juil. 18 20:21:30 2016] usb 1-1.5: New USB device found, idVendor=734c, idProduct=5281
[lun. juil. 18 20:21:30 2016] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[lun. juil. 18 20:21:30 2016] usb 1-1.5: Manufacturer: Turbosight Technolog
Any idea ?
lsusb gives me that :
Bus 001 Device 004: ID 734c:5281 TBS Technologies China
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
gkar
Postby crazycat » Tue Jul 19, 2016 5:01 am
what kernel you have ? look like without i2c mux support, need for si2157/2168 drivers.
Postby steven » Tue Jul 19, 2016 11:04 am
For TBS5281's open source code driver we still on working now ,when we tested it ,we will release to the github.
Postby gkar » Tue Jul 19, 2016 3:09 pm
@crazycat : i use Raspian (debian for Rasp) with this version :
pi@gkar-pi3:~ $ uname -a
Linux gkar-pi3 4.4.13-v7+ #894 SMP Mon Jun 13 13:13:27 BST 2016 armv7l GNU/Linux
I've tried to activate i2c support because it could be switch off in configuration menu of raspian but it doesn't modify the result ...
Result of my dmesg in this file
@steven : great news ... could you send me an email when it's done ... or make a reply there ?
gkar
