Instal HD in MOI+
Instal HD in MOI+
Postby jmarfilho » Sun Jul 17, 2016 2:05 am
I have a question and need for help to solve. How do I install a 2.5 hard drive in my MOI +? Where do I connect the power? I use 5V or 12V? Thanks for any help
jmarfilho
Re: Instal HD in MOI+
Postby jmarfilho » Thu Jul 21, 2016 3:52 am
No one can give me support?
jmarfilho
Postby steven » Mon Jul 25, 2016 6:33 pm
The power pin is near the SATA interface you can use the cable coming from MOI+ .
Postby QTIP » Wed Dec 14, 2016 4:09 pm
For some reason i was not able to mount a sata drive with external power on the MOI+..
When i rebooted the MOI the boot process got stuck at 'starting kernal" also after unplugging the sata drive and reboot still the same message appeared.
Next step was to recover the moi by reloading the software and firmware from a usb drive.
I still wanted to use the drive so i formatted the drive on a different device (EXT4). Mounted the drive in a powered external casing and pugged in the usb slot.
On the display of the moi it showed that a SATA drive was mounted :).
It works fine now.
QTIP
Return to MOI+
