Install problem ubuntu 16.04(Solved)
Postby pote » Fri Jul 15, 2016 4:25 am
I installed the drivers as described and did some troubleshooting - removed, reinstalled again.
lspci lists the cards, but there is no result of dmesg | grep frontend:
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (2) I219-V (rev 31)
02:00.0 Multimedia controller: TBS Technologies DVB-S2 4 Tuner PCIe Card
03:00.0 Multimedia controller: TBS Technologies DVB-S2 4 Tuner PCIe Card
04:00.0 USB controller: ASMedia Technology Inc. ASM1142 USB 3.1 Host Controller
When trying to load the driver manually I get "Required key not available"
root@P:~/drivers/tbs# modprobe -v tbs6909fe
insmod /lib/modules/4.4.0-28-generic/kernel/drivers/media/dvb/frontends/tbs6909fe.ko
modprobe: ERROR: could not insert 'tbs6909fe': Required key not available
I have installed the drivers on an Ubuntu server 16.04 with no problems.
If anyone could guide me in the right direction it would be highly appreciated.
pote
Re: Install problem ubuntu 16.04
Postby crazycat » Fri Jul 15, 2016 5:18 am
disable secure boot in BIOS.
Postby pote » Fri Jul 15, 2016 6:35 am
Thank you so much! That fixed it!
pote
Postby pote » Sun Jul 17, 2016 8:37 am
Some further research lead to additional info that might be useful to others moving to Ubuntu 16.04:
Since Ubuntu kernel 4.4.0-20 the EFI_SECURE_BOOT_SIG_ENFORCE kernel config has been enabled. That prevents from loading unsigned third party modules if UEFI Secure Boot is enabled.
Since Ubuntu kernel build 4.4.0-21.37 this can be fixed by running
sudo apt install mokutil
sudo mokutil --disable-validation
Alternatively you can disable SecureBoot in UEFI aka BIOS.
Here is the link:
http://askubuntu.com/questions/762254/w ... -ubuntu-16
pote
