encoder tbs 2603 always stops
Postby africa12002 » Fri Jul 08, 2016 9:53 am
the stream with the 1.0.43 version always stops
and the other version does not last more than two hours then the audio is separated from the video
and it stops I have more of an encoder tbs 2603 and have regretted buying them
I read that there a 1.0.49 version but not found
I hope that soon you solve this problem to some extent from Italian telecom
ovh in the flow lasts 10 seconds if you use Vodafone lasts longer with other
encoders are not all these problems I bought on trust
tbs of the name, but this time failed to tbs
africa12002
Re: encoder tbs 2603 always stops
Postby Jessie » Fri Jul 08, 2016 4:31 pm
Please use the new software.
https://pan.baidu.com/s/1qYgV16k
Jessie
Postby Alegpl » Fri Jul 08, 2016 6:17 pm
Hi Jessie,
also 1.0.51 doesn't support 2 streams for more than some minutes.
1st h.264, 2nd h.265 -> first crashes after few time, second keeps working
Regards
Alegpl
Postby africa12002 » Fri Jul 08, 2016 7:55 pm
if you can download it in a European site
Chinese do not download
africa12002
Postby steven » Thu Jul 14, 2016 4:47 pm
Please use our latest firmware:
http://www.tbsdtv.com/download/document/tbs2603/tbs2603_upgrade_v1.0.51.zip
