problem with card
problem with card
Postby copycat » Tue Jun 21, 2016 6:55 am
i bought a moi+ with the dvb-c card but that card wont work in my country, im from mexico!.
then i bought another one the tbs6902. well then i remove the dvb-c from the moi+ and put the new dvb-s2 when i power on the moi the card doesnt appear what i need to run correctly the tbs6902 in the moi+ ??
thanks for all sorry my english, my first language is the spanish
copycat
Re: problem with card
Postby steven » Fri Jul 01, 2016 1:17 pm
Hi copycat
Sorry that MOI+ do not support TBS6902 ,and we do not sell MOI+ with 6902,if you want to use 6902 you can put it to your PC .
