Transcoding using FFmpeg
Postby mazen69 » Thu Jun 16, 2016 6:52 am
Dear All
I have a question about transcoding using FFmpeg from Dvblast.
The input is either rtp or udp and the output must be rtmp .
I need help . examples will be appreciated.
Thanks in advanced
mazen69
Re: Transcoding using FFmpeg
Postby ahmedramze » Mon Oct 24, 2016 7:41 am
This example of using TV Headend with RTMP server transcoding using ffmpeg
idea its SAT==> LNB ===> MOI <===> RTMP Linux Server <====> Clients
ffmpeg -re -y -i "http://192.168.1.188:9981/stream/channelid/2?ticket=72E96A4FAE08854FD3E0F0C8863C4F625AF5CCE2" -b 500k -maxrate 500k -bufsize 500k  -r 30  -s 800x600 -acodec libmp3lame  -ar 22100 -f flv "rtmp://127.0.0.1/live/6" >/dev/null &
if you see the line its for change bit rate from HD to 800x600 with 500k for video and 22k for audio.
may be the release of ffmpeg and installation option will be diffrent this done with UBUNTU and ffmpeg with HEVC and RTMP and H264 and mp3 & acc codec option installation.
you can find it by ffmpeg --h
and you can put your steam IP after -i option like -i "udp://224.1.1.1:1234"
any question please send email to [url]support@highspeedtelecom.net[/url] and our team will replay.
Regards
ahmedramze
Return to MOI Pro - AMD
