moi+ and TBS 6281SE
moi+ and TBS 6281SE
Postby jmb26 » Mon Jun 06, 2016 5:28 pm
Hello
my TBS 6281SE is not suported by moi+ (only the TBS 6281)
How can we build compatible drivers ?
Or install a another linux for moi+??
thanks
jmb26
Re: moi+ and TBS 6281SE
Postby yaraforce » Fri Jun 17, 2016 1:28 am
don't even try , find old pc tower with 1 GB ram would be better and cheaper than the box , use it with ubunta 14.4 and would work like charm ,
post here if you face any problems with ubunta and I will help you with it all :)
yaraforce
Return to MOI+
