TBS 6205 and DVB-C not working
Postby satenicu » Thu May 26, 2016 7:13 pm
Dear friends
I have purchased a MOI+ with TBS 6205 tuner board for DVB-C reception.Unfortunately I can not use it for this purpose.With Tv Headend app. I can't declare the network to the tuner for searching it.
I have installed the DVB-S and DVB-C kernel but it dont recognize the tuner board.
Can you help me with this issue.
Thank you
Nicu
satenicu
Re: TBS 6205 and DVB-C not working
Postby pferdone » Thu May 26, 2016 9:41 pm
I've the exact same problem and I'm kinda getting the picture MOI+ doesn't work with the TBS-6205 in DVB-C mode. I already sent a PM to steven and I'm waiting for a reply, but if you take a look at this website MOI+ it says:
    Products works with MOI+:
    DVB-S2:
    TBS6922, TBS6982, TBS6983, TBS6985, TBS6928, TBS6928SE , TBS6991, TBS6991SE, TBS6904
    DVB-T2 :
    TBS6221, TBS6281, TBS6284, TBS6285, TBS6205, TBS6290
    DVB-C :
    TBS6618, TBS6680
You can see that the TBS-6205 is only listed under DVB-T2. If this is true, the shop I bought mine from is VERY misleading Netzwerk-Tuner DVB-S2 Streaming Box, MOI+, because you can select the TBS-6205 as DVB-C tuner and it simply doesn't work. I will send mine back if that's the case...but I hope steven can shed some light on this topic.
pferdone
Postby satenicu » Fri Aug 26, 2016 8:14 pm
Thank's for reply.
satenicu
Postby Milhauzz » Tue Jul 16, 2019 6:01 pm
Hi there,
any update about TBS6205 and DVB-C? I bought used MOI+ without tuner some time ago and I`m thinking which PCIe card should I buy for my DVB-C solution. As I read here, TBS6618 and TBS6680 is DVB-C solution, but "only" as a dual tunner. Is there any other option to have quad tuner (quad or more) on MOI+ for DVB-C?
Thanks in advance for any info.
Milhauzz
Postby steven » Thu Jul 18, 2019 9:46 am
Hi Sir
Please have a try update the kernel to this one :
https://sourceforge.net/projects/moiplu ... %2BV1.0.2/
https://sourceforge.net/projects/moiplus/files/Release/MOI%2BV1.0.2/moi%2B_update_kernel_dvbc_dvbs2_v1.0.2.zip/download
if still can not use please use the 6205 in MOIPro-AMD or with your normal PC .
Postby Milhauzz » Thu Jul 18, 2019 6:45 pm
Steven, tahnk you a lot
is there anybody, who can test this solution? Because I don't have 6205 yet. If not, I will do a risk for buy it and test.
have a nice day
Milhauzz
Postby steven » Fri Jul 19, 2019 10:24 am
Hi Sir
recommend update your MOI+ to MOPro-AMD which support more cards and more powerful and it support 6205 DVB-C all of TBS tuner cards
Return to MOI+
