Which IPTV Streamer fits my needs?
Postby clang » Mon May 23, 2016 2:14 pm
Hi all,
I want to stream DVB-S2 channels to my LAN.
Satellit will be only Astra 19 E with up to two pay-tv providers.
There will be about 5 stationary clients (KODI+ Raspberry PI in sleeping room, childs room, guest room, kitchen and living room) and about 4 mobile clients (3x mobile,1 x tablet).
I would like to know if MOI pro AMD is able to transcode to get better bandwidth for mobile clients, as they are bound to WLAN.
How many Tuners and which would fit my needs?
1 satellite
up to two paytv-providers (i could also live with a softcam solution)
max. 9 clients
transcoding as option
clang
Re: Which IPTV Streamer fits my needs?
Postby steven » Mon May 23, 2016 3:59 pm
Hi clang
Thanks for your interest of our product .if your client is Kodi , you can using MOIPro--AMD with tvheadend ,how many tuner depens on how many
channels you want to receive ,1 tuner for one transponder all uses can watch different channels at the same time.
And for MOIPro-AMD do not support transcode so make sure that your LAN network environment is better ,best is 1Gbps :)
Postby clang » Mon May 23, 2016 5:02 pm
Wow. That was a quick reply.
So for transcoding purpose i would need to build a server with more power and use some tbs dvb-s2 card.
Can you tell me if transcoding is done with power of cpu or gpu?
I think about a setup like that:
AMD FX Series FX-9590 8x 4.70GHz So.AM3+ WOF
16GB Crucial Ballistix Sport DDR3-1600 DIMM CL9 Dual Kit
Gigabyte GA-970-Gaming AMD 970 So.AM3+ Dual Channel DDR3 ATX Retail
128GB SanDisk Z400s M.2 2280 M.2 6Gb/s MLC (SD8SNAT-128G-1122)
Graphics Card??
TBS Quad Tuner DVB-S2, probably TBS6905.
Or similar setup with Intel Core i7 6700K 4x 4.00GHz So.1151 WOF....
Gigabit LAN is available but not for mobile devices. Currently I can stream channels from a Dreambox but it stutters over WiFi. LAN is working fine.
clang
Postby clang » Tue May 24, 2016 1:43 am
Maybe a mod may move this topic where it better fits. I thought this was for general discussokn and not a subforum of this matrix thing..
clang
Return to General discussion
