How to install linux driver
Postby steven » Fri May 06, 2016 9:47 am
Hi all
Here is the detail steps to install the linux driver
#git clone https://github.com/tbsdtv/media_build.git
#git clone --depth=1 https://github.com/tbsdtv/linux_media.git -b latest ./media
#cd media_build
#make dir DIR=../media
#make allyesconfig
#sed -i -r 's/(^CONFIG.*_RC.*=)./\1n/g' v4l/.config
#sed -i -r 's/(^CONFIG.*_IR.*=)./\1n/g' v4l/.config
#make -j4
#sudo make install
reboot pc
# shutdown -r now
detected card
# dmesg | grep frontend
[ 5.672784] DVB: registering adapter 0 frontend 0 (TurboSight TBS 6904 DVBS/S2 frontend)...
[ 6.126936] DVB: registering adapter 2 frontend 0 (TurboSight TBS 6904 DVBS/S2 frontend)...
[ 6.581951] DVB: registering adapter 3 frontend 0 (TurboSight TBS 6904 DVBS/S2 frontend)...
[ 7.039329] DVB: registering adapter 4 frontend 0 (TurboSight TBS 6904 DVBS/S2 frontend)...
[ 7.382843] DVB: registering adapter 1 frontend 0 (TurboSight TBS 6290 DVBT/T2 frontend)...
[ 9.431417] DVB: registering adapter 5 frontend 0 (TurboSight TBS 6290 DVBT/T2 frontend)...
If you still have problem with this please check this part :
https://github.com/tbsdtv/linux_media/wiki/Prerequisites,-Build-errors-and-Rebuilding
or write email to our support#tbsdtv.com .
Re: How to install linux driver
Postby fua » Fri May 19, 2017 4:30 am
After installing these drivers to the tbs6904 card, the mt4170 card stops working, it looks like there is no af9035 module in these drivers. Can i update it? I can not help running the tbs6904 and mt4170 on linux ubnt 16. I would like help.
fua
Postby steven » Fri May 19, 2017 9:42 am
you can have a try with the open source driver :
Postby ahmedramze » Tue Jul 18, 2017 1:55 am
please update the manual
https://www.tbsiptv.com/download/tbs690 ... _guide.pdf
wget https://www.tbsiptv.com/download/common ... 170330.zip
unzip tbs-linux-drivers_v170330.zip
sudo rm -rf /lib/modules/`uname -r`/kernel/drivers/media/*
./v4l/tbs-x86_64.sh
make && make install
shutdown -r now
ls /dev/dvb/
ahmedramze
Postby HenkPoley » Mon Dec 24, 2018 5:43 pm
Just my 2 cents. If you get something like "tbs5680fe: attach failed : 00" in `dmesg`. Try these things:
Unplug the power of your (external) USB DVB device for a few seconds, and possibly reboot your PC / reload the driver.
Secondly, do a `sudo make distclean` in the driver directory before the platform setting, `sudo make -j4` and `sudo make install` steps.
HenkPoley
Return to News
