Octo card driver has problem
Postby kiamax » Wed Apr 27, 2016 4:20 pm
Hello
Octo card driver seems have problem.after install and active each tuner cpu going very busy and system going slow.seems somethings is wrong inside driver because make high load on cpu and each tuner use one core of cpu.for example each octa core need 8 core cpu because each tuner use one core of cpu
kiamax
Re: Octo card driver has problem
Postby kiamax » Wed Apr 27, 2016 4:39 pm
seems you only sell and dont want to support.8 tuners on 4 output its wrong idea.now i have 24 core cpu and even with active 1 card from 4 cards system going very very slow.only search 40 channels and system is slow like 20000 channels on it.this card make cpu too much busy
kiamax
Postby stilmant » Wed Apr 27, 2016 9:31 pm
Please remember to do as advised here for support from sellers: viewtopic.php?f=176&t=2194
regards
stilmant
Postby kiamax » Thu Apr 28, 2016 6:54 am
There is no error on log
but use too much cpu
kiamax
Postby wirre » Fri May 13, 2016 1:41 pm
I have exacly the same problem. If you downgrade the driver, everything is back to normal. I only have 12 CPU cores and 64GB of ram and OS on SSD, but stil hangs :( Tried 4 different variation of ubuntu, and 2 different versions of Tvheadend, but stil same problem.. Old driver works fine..
wirre
