tbs2603
tbs2603
Postby viendoestrellas » Fri Apr 15, 2016 2:00 pm
I recently acquired a tbs2603 it works good on vlc but if I want to watch the stream on ... let's say stalker i just got sound, I changed the source, I changed the HDMI cable and still have the same problem, any ideas what I should do? thank you very much for your help.
viendoestrellas
Re: tbs2603
Postby SergioDanielG » Tue Apr 19, 2016 6:35 pm
Hi viendoestrellas.
It's like a codec problem in your client.
Can you try send stream from your TBS2603 with h.265 and h.264 codec?
And tell us if it works,
Kind regards.
SergioDanielG
Re: tbs2603
Postby echomay » Fri Apr 29, 2016 10:36 am
Which protocol you use, http or rtsp?
Which app on your stalker?
echomay
