TBS 6925 Windows 10 64 bit
Postby borgorosso » Thu Apr 14, 2016 12:20 am
I installed with its cd TBS 6925 on Windows 10 64-bit, but I can not find the devices.
I also installed all the programs on the CD and now my computer recognizes the TBS 6925 as a network adapter (Virtual MPE Decoder Adapter), but I can not use it with other programs (TBS Wiever, DVB Dream...), because they do not find the presence of TBS on my computer.
How can I do?
borgorosso
Re: TBS 6925 Windows 10 64 bit
Postby steven » Thu May 12, 2016 5:46 pm
In your windows device manage dialog can you see the 6925 device ?
if not please have a try change the PCI-E slot check whether is ok
Kind regards
