An Interesting dvblast problem
Postby krmlk » Fri Apr 08, 2016 2:18 am
Dear All,
If I stream and transcode any dvb-t channel through dvblast everything goes well but if I stream and transcode second channel (of course with another multicast IP) the first channel being to last channel. If I set another stream then being all streams the last stream.
What is this reason?
krmlk
Re: An Interesting dvblast problem
Postby steven » Fri Apr 08, 2016 11:50 am
Hi krmlk
what about your transcode config ? maybe use the wrong source input ? at the same time you can using the multi address to play in your PC check the channel whether is the same from transcode .
Postby krmlk » Fri Apr 08, 2016 2:59 pm
steven Wrote:Hi krmlk
It doesn't matter if I transcode the stream or not. I set up a stream in xtream and testing from there (mepg or hfs) . I am pretty sure I am using for every stream own ip so there is no any wrong source
krmlk
Postby steven » Thu May 12, 2016 5:44 pm
Do you streaming from the dvblast web page ? can you send a picture about your dvblast streaming setting dialog ?
we will have a check
Kind regards
Postby krmlk » Fri May 13, 2016 7:24 pm
I have started to use mumudvb (unicast). Many thanks
krmlk
Return to MOI Pro - AMD
