TBS5520 Questions
TBS5520 Questions
Postby jwaiv » Fri Mar 25, 2016 8:22 pm
I can't find a specific forum for this but I've been looking at getting a TBS5520 and I've got a couple of questions regarding the product.
1. Is it suitable to receive Freesat in the UK?
2. It seems to be totally powered by USB, as far as I know USB connections can only provide 5v so I was curious how the tuner would supply 9/13v to an LNB. Would I need any additional equipment to provide power to the LNB?
Thanks!
jwaiv
Re: TBS5520 Questions
Postby steven » Tue Aug 09, 2016 4:42 pm
1. It is ok you can receive Freesat in UK
2.It is ok 5520 will auto handle it do not additional equipment ,just do not connect a motor if direct connec the singal cable to 5520 is no problem
thanks
