Black screen with belgian channels
Postby LovePreacher » Thu Mar 17, 2016 3:11 am
My TBS6290 tuner doesn't work with FTA belgian channels, I get a black screen even if I receive a good signal.
For watching TV on my PC, I use DVBViewer Pro 5.3.2, VLC or MPC-HC on Windows 7 x64 SP1. It seems that there is an issue with the latest provided drivers or maybe my tuner is defective.
LovePreacher
Re: Black screen with belgian channels
Postby smile » Fri Apr 01, 2016 3:01 pm
HI ,
Is it just black screen? can you hear the channels voice?
Best Regards
smile
Postby LovePreacher » Mon Apr 04, 2016 4:47 pm
Hi smile,
It's black screen with no audio. However, I found that the problem is linked to Crazyscan 2. After I used this software, the issue appears. I have to disable and then enable the tuner in the device manager to get the thing working again. Maybe the way that Crazyscan access the hardware is the culprit.
LovePreacher
Return to DVB-T2/T/C Dual Tuner Dual CI PCIe Card TBS6290
