TBS 2911
TBS 2911
Postby milius » Thu Mar 10, 2016 6:54 pm
Hi , I have a 2911 model TBS version MOI PRO v1.0.0.10 , headend - Linux MOIPro 3.14.34-02243 - g1f9fe39 -dirty # 142 SMP Wed Jan 27 10:33:53 CST 2016 armv7l GNU / Linux . When you try to update you get opkg : Downloading http://sourceforge.net/projects/openpct ... //Packages .
Collected errors:
* Opkg_download : Failed to download http://sourceforge.net/projects/openpctv/fi Forest / packages // Packages : Problem with the SSL CA cert ( path ? Access rights ?) .
Is there any way to solve the problem ?
Sorry for the ignorance , I am a novice at this . Thank you very much.
milius
Re: TBS 2911
Postby steven » Fri Mar 11, 2016 6:07 pm
hi milius
For MOIPro do not support update like this,if you want to update you can using our latest firmware and tools to update.
Here is the guide:
http://www.tbsdtv.com/download/document ... o-V1.3.pdf
Re: TBS 2911
Postby milius » Fri Mar 11, 2016 7:15 pm
Hi Steven ,
Thanks for the reply , but all these actions were carried out correctly , I also tried to downgrade and upgrade , but since I need to update the drivers , so I tried opkg update , but still writes me a problem with certificates . I thought opkg update will assist problem.
milius
Re: TBS 2911
Postby milius » Fri Mar 11, 2016 10:19 pm
In what way can be upgraded to version 4.0.8-17 tvheadend ~ gd82a025 ? Maybe it would solve the issue of certificates. Ask detailed guidance update. I am a novice in this , thank you very much.
milius
Re: TBS 2911
Postby even » Tue Mar 22, 2016 6:22 pm
Hi milius
The driver need to update our firmware , the tvheadend when we release the firmware we usually update the tvheadend to latest version,
even
Site Admin
Return to MOI Pro
