TBS6920 & MOI+
TBS6920 & MOI+
Postby simonjboyle » Sun Feb 21, 2016 10:06 pm
I have a TBS6920 installed in my moi+ box, but the adapter is not appearing in the tvheadend gui. Does anyone know if its possible to get this card working with the moi+, or even how to tell if the os is recognising it using SSH?
simonjboyle
Re: TBS6920 & MOI+
Postby SergioDanielG » Mon Feb 22, 2016 12:22 am
Hi simonjboyle.
You can try login in to MOI+ using ssh, then:
# ls /dev/dvb
Output must be like
adapter0 adapter1
One adapter per each tuner on your device.
If you have adapters:
# dvbsnoop -s feinfo -adapter x
Where "x" is adapter's number
In my case, for adapter 0, output is
dvbsnoop V1.4.50 -- http://dvbsnoop.sourceforge.net/
FrontEnd Info...
Device: /dev/dvb/adapter0/frontend0
Basic capabilities:
    Name: "TurboSight TBS 6903 DVBS/S2 frontend"
    Frontend-type:       QPSK (DVB-S)
    Frequency (min):     950.000 MHz
    Frequency (max):     2150.000 MHz
    Frequency stepsiz:   1.011 MHz
    Frequency tolerance: 5.000 MHz
    Symbol rate (min):     1.000000 MSym/s
    Symbol rate (max):     67.500000 MSym/s
    Symbol rate tolerance: 0 ppm
    Notifier delay: 0 ms
    Frontend capabilities:
        auto inversion
        FEC 1/2
        FEC 2/3
        FEC 3/4
        FEC 4/5
        FEC 5/6
        FEC 6/7
        FEC 7/8
        FEC AUTO
        QPSK
Current parameters:
    Frequency:  1920.000 MHz
    Inversion:  AUTO
    Symbol rate:  30.000000 MSym/s
    FEC:  FEC 5/6
Kind regards.
SergioDanielG
Re: TBS6920 & MOI+
Postby simonjboyle » Mon Feb 22, 2016 5:27 am
Hi SergioDanielG and thanks
I did this but no adapters are listed.
[root@moi /]# ls -ls /dev/dvb
total 0
[root@moi /]#
My TBS 6920 card is not on the compatability list for the MOI+, is that why they do not appear do you think?
If not, is there a way of getting the required drivers on there? Suppose I would need arm drivers (may have to compile them?)
simonjboyle
Re: TBS6920 & MOI+
Postby costan » Mon Feb 22, 2016 7:03 pm
Please post /var/log/messages file contents, as well as dmesg command output (use ssh as before).
Probably you need the firmware file.
costan
Re: TBS6920 & MOI+
Postby simonjboyle » Mon Feb 22, 2016 7:51 pm
Hmmm, thanks all.
I have had this reply from TBS support - for anyone else trying to do this, I am posting below:
Hi Simon
Sorry that MOI+ can not use with 6920, as TBS6920 PCI-E bridge code can not compiled in MOI+,so this is why
we have not added this support ,if you want to use DVB-S tuner with MOI+,you can have a look at our TBS6922SE.
Kind regards
I'm not sure its worth pursuing anymore, any thoughts?..
simonjboyle
Re: TBS6920 & MOI+
Postby simonjboyle » Mon Feb 22, 2016 8:37 pm
dmesg output attached
dmesg.zip
(5.04 KiB) Downloaded 995 times
simonjboyle
Re: TBS6920 & MOI+
Postby costan » Mon Feb 22, 2016 8:38 pm
simonjboyle Wrote:dmesg output attached
??? I don't see it...???
costan
Re: TBS6920 & MOI+
Postby simonjboyle » Mon Feb 22, 2016 8:39 pm
Sorry posted now!
simonjboyle
Re: TBS6920 & MOI+
Postby costan » Mon Feb 22, 2016 8:43 pm
simonjboyle Wrote:Sorry posted now!
Unfortunately the TBS support was right.
It's the entire driver missing, not just the firmware.
Maybe you can try to cross compile the kernel module, but I managed to cross compile user-space code only. Never tried with the kernel side.
costan
Re: TBS6920 & MOI+
Postby simonjboyle » Mon Feb 22, 2016 8:46 pm
Thanks costan, as I suspected.. New card it is then.... I have a TBS 6982 to try next!
simonjboyle
Return to MOI+
