TBS5520 switch between dvb-s and dvb-c
Postby dce » Thu Feb 18, 2016 9:26 pm
Hello i have de TBS5520 and in linux i don´t know how can i switch between dvb-s and dvb-c and backwards.
thanks
dce
Re: TBS5520 switch between dvb-s and dvb-c
Postby orson » Fri Feb 19, 2016 12:05 am
Hi!
You could try following on command line (works on my Hauppauge-card):
dvb-fe-tool -a <adapter-nr> -d "<delivery system>"
like:
dvb-fe-tool -a 2 -d "DVBC/ANNEX_A"
To get a list of supported delivery systems just set the adapter-nr like:
dvb-fe-tool -a 2
Output:
Device Silicon Labs Si2168 (/dev/dvb/adapter2/frontend0) capabilities:
CAN_2G_MODULATION
CAN_FEC_1_2
<removed> ...
CAN_QPSK
CAN_TRANSMISSION_MODE_AUTO
DVB API Version 5.10, Current v5 delivery system: DVBC/ANNEX_A
Supported delivery systems:
DVBT
DVBT2
[DVBC/ANNEX_A]
orson
Postby steven » Sat Feb 20, 2016 6:17 pm
Hi all
TBS5520 only support change dvbs to dvbc in windows now ,for linux we will support it in next driver .
Kind regards
Postby dce » Wed Feb 24, 2016 5:59 pm
thanks, and when the driver for Linux will be available?
dce
Postby reydecopas » Wed Mar 23, 2016 8:38 pm
tying to install v160219...
I am able to watch DVB-T in Windows but not DVB-S, and w_scan DVB-S in linux...
Any update in switching between dvb-s and dvb-T in linux?
reydecopas
Postby Tnix » Thu Mar 24, 2016 12:31 am
Hi all,
I've recently adquired a TBS5520 tuner and I can watch DVB-T and DVB-S in Windows 10 x64 through SichboPVR. I also can switch succesfully between both TV systems with the Windows utility downloaded from TBS drivers page. But I cannot switch between both TV systems in Linux. I only can wath DVB-S through Kaffeine. The frontend offered by the Linux driver only can work with DVB-S. How can I switch to DVB-T too?
Thanks.
Tnix
Postby Tnix » Fri May 20, 2016 8:30 pm
Hi all,
I've just updated to the new drivers 160405 and it appears that DVB-T, DVB-S and DVB-C switching cannot be performed yet or if it's possible the way doesn't write down in any place ...
So nowadays TBS5520 is ONLY FULLY working on Windows ... On Linux it only works DVB-S/DVB-S2 ... isn't it? Sad ...
Tnix
Postby crazycat » Sun May 22, 2016 2:49 am
try open-sourcve driver with multistandard tuner/frontend driver for TBS 5520 - https://bitbucket.org/CrazyCat/media_build
P.S. ISDB-T support not implemented yet. Only DVB-S/S2, T/T2 and cable.
Postby reydecopas » Mon May 23, 2016 11:43 pm
Hi crazycat,
Could you please post the installation steps to build the repo and the drivers? Which distro do you prefer for testing the drivers?
Could you please post the kernel version and the distro you use to test your repo?
reydecopas
Postby crazycat » Tue May 24, 2016 3:44 am
Usual media_build, installation procedure in README.
some like this:
git clone https://bitbucket.org/CrazyCat/media_build.git
cd media_build
./build
sudo make install
Build script download latest sources snapshot, apply patches for current kernel and make. For developer purposes possible use sources from git media_tree with --main-git or --git options.
If you need include some staging media drivers (legacy lirc, unfinished frontend drivers and etc) use included script install.sh after first build.
This install.sh:
#!/bin/bash
# Enable some staging drivers
make stagingconfig
echo "V4L drivers building..."
make -j4
echo "V4L drivers installing..."
sudo rm -r -f /lib/modules/$(uname -r)/kernel/drivers/media
sudo rm -r -f /lib/modules/$(uname -r)/kernel/drivers/staging/media
sudo make install
echo "V4L drivers installation done"
echo "You need to reboot..."
