TBS6985 Unicable configuration
Postby christerj77 » Thu Feb 18, 2016 3:30 pm
Im trying to get the TBS6985 working with a Inverto Unicale LNB, a 4-way splitter and tvheadend.
I set up the frequencys for unicable configuration to 1210, 1420, 1680 and 2040, is that the correct settings?
The problem is i get good signal on only 1 tuner and it seams like the best frequency is 1210.
Products i use
http://www.inverto.tv/products/product.php?id=159
http://satvision.se/splitter-4-vags-5-2400-mhz.html
christerj77
Re: TBS6985 Unicable configuration
Postby christerj77 » Thu Feb 18, 2016 4:30 pm
I missed one setting, you need to set SCR (ID) for each adapater, for 1210 mhz it is SCR 0, for 1420 it is SCR 1 and so on
christerj77
