TBS 6221 DVB-C (cable) card under Linux (Debian 8 x64)
Postby Geniusxxx » Sun Feb 14, 2016 4:34 am
I’m having problems using the TBS 6221 DVB-C (cable) card under Linux (Debian 8 x64) ) in a ESXi 5.5 virtual machine. From here on ‘all’ the systems I refer to are running in virtual environments.
The card seems to work fine under Windows 7 Pro, but under Debian it does not seem to be able to tune to anything.
The card is in a TVHeadend 4.1-1347 server alongside a TBS 6985 (Quad Satellite) card. The latest driver at the time of writing (tbs-linux-drivers_v160126) seems to have compiled and installed with no problems.
root@vmtvh:~# dmesg | grep frontend
[ 19.377523] DVB: registering adapter 0 frontend 0 (TurboSight TBS 6985 DVBS/S2 frontend)...
[ 19.938991] DVB: registering adapter 1 frontend 0 (TurboSight TBS 6985 DVBS/S2 frontend)...
[ 20.591020] DVB: registering adapter 2 frontend 0 (TurboSight TBS 6985 DVBS/S2 frontend)...
[ 21.142459] DVB: registering adapter 3 frontend 0 (TurboSight TBS 6985 DVBS/S2 frontend)...
[ 24.052383] DVB: registering adapter 4 frontend 0 (TurboSight TBS 62x1 DVBC frontend)...
[ 49.617021] DVB: adapter 4 frontend 0 symbol rate 6952 out of range (1000000..7200000)
[ 578.232124] DVB: adapter 4 frontend 0 symbol rate 6952 out of range (1000000..7200000)
[37453.203208] DVB: adapter 4 frontend 0 symbol rate 0 out of range (1000000..7200000)
[37891.759070] DVB: adapter 4 frontend 0 symbol rate 0 out of range (1000000..7200000)
The satellite side of things is working fine :D , but when trying to scan cable via the 6221 I get the following from TVHeadend :cry:
******** Output from TVHeadend ***********************************************************
2016-01-31 14:23:22.002 mpegts: 411MHz in Cable2 - add raw service
2016-01-31 14:23:22.003 service: 2: 411MHz in Cable2 si 0x31c2c10 TurboSight TBS 62x1 DVBC frontend : DVB-C #0 weight 0 prio 10 error 0
2016-01-31 14:23:22.003 mpegts: 411MHz in Cable2 - tuning on TurboSight TBS 62x1 DVBC frontend : DVB-C #0
2016-01-31 14:23:22.004 linuxdvb: TurboSight TBS 62x1 DVBC frontend : DVB-C #0 - starting 411MHz in Cable2
2016-01-31 14:23:22.004 linuxdvb: TurboSight TBS 62x1 DVBC frontend : DVB-C #0 - failed to tune [e=Invalid argument]
2016-01-31 14:23:22.005 settings: saving to /home/hts/.hts/tvheadend/input/dvb/networks/b0113a291b32b30044693bcd84804773/muxes/f6861ba5d2047c9b1a8c35a2efe20d54/config
2016-01-31 14:23:36.002 dvr: checking free and used disk space for config "Default profile" : OK
2016-01-31 14:23:51.000 dvr: checking free and used disk space for config "Default profile" : OK
So I ran the ‘scan utility to try and see what was happening:-
******** scan *****************************************************************************
scan -a 4 -f 0 /usr/share/dvb/dvb-c/
root@vmtvh:~# scan -a 4 -f 0 /usr/share/dvb/dvb-c/
scanning /usr/share/dvb/dvb-s/
using '/dev/dvb/adapter4/frontend0' and '/dev/dvb/adapter4/demux0'
ERROR: initial tuning failed
dumping lists (0 services)
Done.
Then I tried ‘w_scan’, which threw out the following:-
******** w_scan ***************************************************************************
w_scan -a 4 -fc -c GB -S 4 -x >> /tmp/w_scan.log
root@vmtvh:~# w_scan -a 4 -fc -c GB -S 4 -x >> /tmp/w_scan.log
w_scan version 20141122 (compiled for DVB API 5.10)
using settings for UNITED KINGDOM
DVB cable
DVB-C
scan type CABLE, channellist 7
output format initial tuning data
WARNING: could not guess your codepage. Falling back to 'UTF-8'
output charset 'UTF-8', use -C <charset> to override
Using DVB API 5.3
frontend 'TurboSight TBS 62x1 DVBC frontend' supports
INVERSION_AUTO
QAM_AUTO
FEC_AUTO not supported, trying FEC_NONE.
FREQ (42.00MHz ... 1002.00MHz)
SRATE (1.000MSym/s ... 7.200MSym/s)
WARNING: YOU ARE USING OUTDATED DVB DRIVERS.
73000: sr6952 (time: 00:00.000)
81000: sr6952 (time: 00:01.595)
113000: sr6952 (time: 00:04.623)
121000: sr6952 (time: 00:07.647)
129000: sr6952 (time: 00:10.667)
. I skipped the output in between to keep this post short.
818000: sr6952 (time: 07:47.891)
826000: sr6952 (time: 07:50.915)
834000: sr6952 (time: 07:53.935)
842000: sr6952 (time: 07:56.955)
850000: sr6952 (time: 07:59.975)
858000: sr6952 (time: 08:06.723)
ERROR: Sorry - i couldn't get any working frequency/transponder
Nothing to scan!!
root@vmtvh:~#
I would like to get this sorted so I can upgrade and move onto a TBS 6205 ☺
Any advice would be appreciated.
Thanks :D
Geniusxxx
