tbs5990 upset on linux driver support
Postby highkick05 » Sun Jan 24, 2016 4:53 pm
Hi , I am very unhappy of this product has no updated linux drivers into current kernel from 6 years ago.
I don't even think this device was made 6 years ago, no it was only manufactured I think couple years ago.
Why tbs ? This is bad support for your hardware. please update drivers so they work with other devices in linux !
The results is you can't use it along with other hardware in linux, this is very poor bad compatibility
highkick05
Re: tbs5990 upset on linux driver support
Postby SergioDanielG » Sun Jan 24, 2016 9:11 pm
Hi higkick05, TBS drivers works with un newest kernels, I test it un kernel versión 4.3.
Yesterday I helped a user to install drivers of other devices.
I don't know what do you need install, but maybe I can hepl you.
Kind regards
SergioDanielG
Postby Alfredo » Tue Jan 26, 2016 9:20 am
Hi SergioDanielG
I think highkick05 exposes something like this: viewtopic.php?f=47&t=8678
Cheers
Alfredo
Postby highkick05 » Wed Jan 27, 2016 9:49 pm
SergioDanielG Wrote:Hi higkick05, TBS drivers works with un newest kernels, I test it un kernel versión 4.3.
Kind regards
Thank for response
I need the avermedia volar green HD dvb-t stick to work with tbs5990 dvb-s driver
It works in all default media_build , default openelec and kernels. Just not with tbs drivers.
I was surprised bcos support for this is good. Appreciate if you can help
highkick05
Postby SergioDanielG » Wed Jan 27, 2016 11:17 pm
Hi highkick05, give me a link to download driver used by the avermedia volar green HD dvb-t stick and I can try install it with tbs drivers.
Kind regards.
SergioDanielG
Postby highkick05 » Thu Jan 28, 2016 12:10 am
SergioDanielG Wrote:Hi highkick05, give me a link to download driver used by the avermedia volar green HD dvb-t stick and I can try install it with tbs drivers.
Kind regards.
They hav no official linux driver but runs easily with, in most kernels native
https://www.linuxtv.org/wiki/index.php/Afatech_AF9035
this is the chipset of stick, common it seems in lot dvb-t
AVerMedia AVerTV AverTV Volar HD & HD PRO (A835) ✔ Yes (unofficial) 07ca:a835 USB2.0 AF 9035
Found another post regards the stick:
Re: Card not detected on Ubuntu 13.04 x64 (kernel 3.8)
Postby chgil » Tue Dec 03, 2013 9:21 pm
what is the command for compile???
Excuse me but i have 2 usb DTT with af9035, but not function, with tbs6981.
not i have solution
Did you have solution for me?
gilberto from italy
Would be interested if u get working
highkick05
Postby highkick05 » Thu Jan 28, 2016 11:02 am
Solution on this page, may help solve integration with tbs drivers
http://askubuntu.com/questions/70382/in ... ech-af9035
highkick05
Postby highkick05 » Sat Jan 30, 2016 10:19 am
Kind regards.
Any luck getting the Avermedia 835B it into the mainline tbs drivers ?
Why can't TBS just build your linux drivers like windows drivers ?
I don't understand why you continue to support your linux drivers like this. Why do you keep backport to old kernel base, you leave out many needed hardware
highkick05
Postby SergioDanielG » Wed Feb 03, 2016 11:12 am
Kind regards.
Hi highjick05, I'm not at home, I'll back in few day and I'll try again with other drivers.
And please, tell me, which OS and kernel are you using?
Kind regards.
SergioDanielG
Postby highkick05 » Wed Feb 03, 2016 1:15 pm
I just built crazycat master on kernel is 4.2.0-27-generic .. it's ubuntu 15.10 update, upgrade & dist-upgrade 'd
has included af9015.ko & but wanting af9033.ko for this device.
Not sure why has avoided but could be intentional .. unsure. maybe u find out thanks
highkick05
Return to News
