Moi pro-amd tvheadend
Postby mudasaraziz » Sun Jan 24, 2016 2:39 am
Hi how to use tvheadend low Bitrate I'm using moi pro amd with xtreamcode as load balance I could only stream 55 channels if I stream more then 55 channels streams keep re setting. I'm using http://127.0.0.1:9981 to stream on to xtreamcode. Any advice please I would be great full.
Thank you
mudasaraziz
Re: Moi pro-amd tvheadend
Postby diabloss » Fri Jan 29, 2016 1:11 am
drop tvheadend....no good
use cesbo astra instead which is lightweight and easier to use
diabloss
Return to MOI Pro - AMD
