1080p streams glitches
Postby scarface79 » Sat Jan 09, 2016 7:14 pm
Hi i have a internet conection of 1000 mb down and upload.
They told me that moi pro can stream 20 channels 1080p resolution but if i put 3 streams sometimes with 1 stream to my xtream codes panel it begins to glitches.
I really tried everthing transcode the stream with no succes.
Can somebody help me please.
scarface79
Re: 1080p streams glitches
Postby scarface79 » Mon Jan 11, 2016 3:05 am
nobody can hekp me ?
scarface79
Postby senkron24 » Tue Jan 12, 2016 7:21 pm
contackt me in privet i can help you or on my mail
senkron24 @ gmail. com
senkron24
Postby lordh » Mon Feb 15, 2016 7:54 pm
I have tested MOI Pro with many possibilities of configurations: 2x double dvbs2 tuner cards with CI, 1x double CI dvbs2 and one DVB-t quad, 2x quad dvbs2. The results is still the same: MOI Pro is "piece of crap". It's to weak to handle more than about 20-30Mbps of stable stream. It's no matter it's fta channel or decoded by CI. MOI Pro AMD is stable with the same cards. I tested firmwares from 1.0.0.3 to 1.0.0.10 with the same results. Whe you use tsdecrypt it's more terrible.
During working sattelite signal is excelent.
My advice: Do not buy MOI Pro! It's waste of money!
Buy MOI Pro AMD or good PC like Dell Power Edge.
lordh
Postby steven » Tue Feb 23, 2016 6:18 pm
lordh Wrote:I have tested MOI Pro with many possibilities of configurations: 2x double dvbs2 tuner cards with CI, 1x double CI dvbs2 and one DVB-t quad, 2x quad dvbs2. The results is still the same: MOI Pro is "piece of crap". It's to weak to handle more than about 20-30Mbps of stable stream. It's no matter it's fta channel or decoded by CI. MOI Pro AMD is stable with the same cards. I tested firmwares from 1.0.0.3 to 1.0.0.10 with the same results. Whe you use tsdecrypt it's more terrible.
Hi lordh
Sorry about the inconvenience,just know that you are using TBS6205 + TBS6991SE ,this two card using two different PCI-E bridge ,TBS6991SE is NXP7160
TBS6205 is ECP3,MOIPro for ARM platform can not support two different PCI-E bridge ,this is the problem .
Return to MOI Pro
