[Help] Diseqc is not working with DVB Dream
Postby maunmodi » Tue Dec 22, 2015 10:23 am
Recently I have purchased TBS S5922SE DVB-S2 USB tuner from www.buydvb.net.
The tuner is working fine with single Ku-band LNB and DVB Dream on my Windows 10 64-bit OS PC.
But recently I have added another Ku-band LNB with a Diseqc 2.0 4x1 switch.
LNB1 attached to Port-1 and LNB2 is attached to Port-2.
Now in DVB Dream (v 2.7.4) only LNB1 is working and LNB2 is not working.
Means DVB Dream shows the signal and also locks it too, but shows no channels found !!!!
Also if I have scanned the channels earlier, it does not play/render the channel of LNB2.
Please help, seems like I have bought a faulty/sub-standard tuner from TBS :(
maunmodi
Re: [Help] Diseqc is not working with DVB Dream
Postby mjahabarsadiq » Mon Oct 31, 2016 3:39 am
This thread didn't get any answer till now. I am also facing the issue in dvb dream. Earlier I reported the exact issue in 5990 but it was working in dvb dream. But in case of 5922 SE, it is not working in dvb dream itself.
The thread link for 5990 is below.
http://dreamdth.com/showthread.php?tid=146002
It is happening with same ports only.
Note: 5922 SE driver version is 1.0.0.5. 5990 driver version is 1.0.0.6. Will 5922SE work with 1.0.0.6 of 5990?
mjahabarsadiq
Postby crazycat » Mon Oct 31, 2016 9:49 pm
check 5922 entry DVBDream\Devices\bda_extensions\conf.ini
some like this
TBS 5922 USB DVB-S2 Tuner=tbs.ext
Postby mjahabarsadiq » Mon Oct 31, 2016 11:09 pm
crazycat Wrote:check 5922 entry DVBDream\Devices\bda_extensions\conf.ini
some like this
Yes, it is there as below..
mjahabarsadiq
Postby crazycat » Tue Nov 01, 2016 2:05 am
check logs
DVBDream\Logs\bda.log
DVBDream\Logs\bdaext.log
P.S. This actual for modern DVBDream's with internal BDA module and ext-submodules. Maybe 2.4+. Anyway you can try streamreader module in DD 3.0+ or alternative BDA module (compatible with DD 1.5e+)
P.P.S. and check latest DvbDream TBS-OEM from downloads :)
