DVB-S2 not working using dvblast
Postby nrm » Tue Dec 15, 2015 12:05 am
I have two TBS devices in a Intel equipment.
TBS6991SE and a TBS6905
Drivers - 151105
Test frequency Hispasat 10730 H 27500
- 6991SE is able to lock when no modulation is used in command line (dvblast legacy)
- 6905 is not. I don't see any lock. I only see sync being acquired and lost, using dvblast.
Is this a limitation in the 6905? Can't 6905 automaticly switch to 8PSK in case of DVB-S2?
nrm
Re: DVB-S2 not working using dvblast
Postby nrm » Tue Dec 15, 2015 2:14 am
Didn't have this problem in the TBS6985.
nrm
Postby SergioDanielG » Thu Dec 17, 2015 1:26 am
Hi nrm.
Can you run femon on both cards and show me output of "femon -H"?
I have siminlar problen with other card.
Thanks in advance.
SergioDanielG
Postby nrm » Sat Dec 19, 2015 4:49 am
Hispasat 10730 H 27500 on both tuners. This is my output :?
FE: TurboSight TBS 6991SE DVBS/S2 frontend (DVBS)
status SCVYL | signal 74% | snr 95% | ber 67108863 | unc 0 | FE_HAS_LOCK
status SCVYL | signal 74% | snr 94% | ber 67108863 | unc 0 | FE_HAS_LOCK
status SCVYL | signal 74% | snr 93% | ber 67108863 | unc 0 | FE_HAS_LOCK
FE: TurboSight TBS 6905 DVBS/S2 frontend (DVBS)
status SCVYL | signal 53% | snr 93% | ber 0 | unc 0 | FE_HAS_LOCK
status SCVYL | signal 53% | snr 92% | ber 0 | unc 0 | FE_HAS_LOCK
nrm
Postby steven » Mon Dec 21, 2015 10:41 am
Hi Nrm
As TBS6905 using ST chip not the one as TBS6991SE and TBS6985.
For ST chip it need to input the modulation parameter for DVB-S2 signal.It is normal.Please do not worry about this.
Kind regards
