[ Moderator Control Panel ]
by diudiumeile » Mon Dec 07, 2015 3:39 pm
Author of the article: Michael Stevens. From:
http://www.geo-web.org.uk/Michael Stevens from
http://www.geo-web.org.uk/ lately tested TBS6908 Professional DVB-S2 Quad Tuner PCIe Card and gave some technical details about this unit. Michael has been running tbs6908 since July/August 2014 without any problems at all. For more details, please refer to the article written by him from:
http://pc.cd/u5artalK
diudiumeile
by SergioDanielG » Fri Dec 11, 2015 1:27 am
Hi diudiumeile.
Do you know if there are some similar test of this card using linux drivers?
Regards.
SergioDanielG
by crazycat » Fri Dec 11, 2015 5:39 am
what test you want ?
i check it - MIS+PLS supported.
by SergioDanielG » Thu Dec 17, 2015 1:04 am
Hi crazycat.
Basically, I want to know if this card works fine with linux OS and all it features, and some experience using all tuners at some time.
Thanks for reply.
Kind regards.
SergioDanielG
