2x 6982 fe has no lock. status:_____
Postby bokerom » Tue Nov 17, 2015 4:26 am
I have 2 6982 in ubuntu server 14.04, I trying to launch for 1 week but no work for me.
I am using astra cesbo (https://cesbo.com/en/astra/) but when i try to scan DVBS1 can not find channels. But if is DVBS2 find signal and channel. Under DVBdream work correct in windows. But not in ubuntu.
The signal and cable is correct.
dmesg | grep frontend
[ 5.954376] DVB: registering adapter 0 frontend 0 (TurboSight TBS 6982SE DVBS/S2 frontend)...
[ 6.507805] DVB: registering adapter 1 frontend 0 (TurboSight TBS 6982SE DVBS/S2 frontend)...
[ 7.080263] DVB: registering adapter 2 frontend 0 (TurboSight TBS 6982SE DVBS/S2 frontend)...
[ 7.632706] DVB: registering adapter 3 frontend 0 (TurboSight TBS 6982SE DVBS/S2 frontend)...
after try scan..show this message;
WARNING: [dvb_input 0:0] fe has no lock. status:_____
WARNING: [dvb_input 1:0] fe has no lock. status:_____
WARNING: [dvb_input 2:0] fe has no lock. status:_____
WARNING: [dvb_input 3:0] fe has no lock. status:_____
In the configuration I tested all the combinations:
Fec: auto...x/x...
Roll-off: Default:35
Modulation: QPSK... AUTO
With always same result...
Same problem with scan-s2 / transponder DVB-S NO services but transponder DVB-S2 find "services"
Any one can help me, please?
A lot of thankyou in advance
Regars.
bokerom
Re: 2x 6982 fe has no lock. status:_____
Postby suayb » Wed Nov 18, 2015 12:18 am
I confirm that.
*i'm using Debian Unstable
*i purchased my card one week ago
suayb
Postby bokerom » Wed Nov 18, 2015 5:17 am
Any solution?, or maybe we need to get RMA for the products.
Regards.
bokerom
Postby suayb » Wed Nov 18, 2015 7:51 am
Unfotunately i haven't found any solution.
suayb
Postby WalstonTempest » Thu Nov 19, 2015 4:17 am
Is your firmware getting loaded ok? Plus sometimes having two cards causes issues.
WalstonTempest
Postby WalstonTempest » Thu Nov 19, 2015 4:32 am
Although this link is not specific to your cards I think will help point you in the right direction, see the trouble shooting section.
http://linuxtv.org/wiki/index.php/TBS6280
WalstonTempest
Postby WalstonTempest » Thu Nov 19, 2015 10:52 pm
And in doing some scouting I came accross this https://freetoairamerica.wordpress.com/ ... your-irqs/
WalstonTempest
