Kernel oops when unloading "saa716x_tbs_dvb"
Postby pstumbler » Tue Nov 17, 2015 1:36 am
I'm getting a kernel oops when removing the saa716x_tbs_dvb module with "rmmod saa716x_tbs_dvb".
I'm using the latest TBS drivers (tbs-linux-drivers_v151105.zip), everything is compiled correctly and also all TBS drivers loads correct and are working.
[ 5354.127624] ------------[ cut here ]------------
[ 5354.127629] WARNING: CPU: 0 PID: 11900 at /build/linux-lts-vivid-6tG2ln/linux-lts-vivid-3.19.0/kernel/module.c:963 module_put+0x8f/0xa0()
[ 5354.127630] Modules linked in: nls_iso8859_1 rc_tbs_nec(OE) ir_lirc_codec(OE) lirc_dev(OE) tbs6982fe(POE) tbs6680fe(POE) tbs6923fe(POE) tbs6985se(POE) tbs6928se(POE) tbs6982se(POE) tbs6991fe(POE) ir_mce_kbd_decoder(OE) tbs6618fe(POE) ir_sony_decoder(OE) tbs6983fe(POE) saa716x_core(OE) ir_jvc_decoder(OE) tbs6922fe(POE) ir_rc6_decoder(OE) tbs6928fe(POE) ir_rc5_decoder(OE) tbs6991se(POE) ir_nec_decoder(OE) tbs6290fe(POE) stv090x(OE) dvb_core(OE) rc_core(OE) ppdev intel_rapl snd_hda_codec_hdmi iosf_mbi x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm crct10dif_pclmul crc32_pclmul ghash_clmulni_intel cryptd serio_raw snd_hda_intel i915 lpc_ich shpchp mei_me snd_hda_controller mei snd_hda_codec snd_hwdep snd_pcm drm_kms_helper snd_timer drm snd soundcore i2c_algo_bit 8250_fintek parport_pc video tpm_infineon mac_hid lp parport raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor ahci libahci r8169 raid6_pq mii raid1 raid0 multipath linear [last unloaded: saa716x_tbs_dvb]
[ 5354.127671] CPU: 0 PID: 11900 Comm: rmmod Tainted: P           OE  3.19.0-33-generic #38~14.04.1-Ubuntu
[ 5354.127672] Hardware name: Gigabyte Technology Co., Ltd. B85M-HD3/B85M-HD3, BIOS F12 08/13/2015
[ 5354.127673]  ffffffff81a962e8 ffff8800b847fe18 ffffffff817af41b 0000000000000000
[ 5354.127675]  0000000000000000 ffff8800b847fe58 ffffffff81074daa ffffffff81c4eba0
[ 5354.127677]  ffff8800d922ea00 ffffffffc045ab20 ffffffffc06736c0 ffffffffc0673498
[ 5354.127680] Call Trace:
[ 5354.127685]  [<ffffffff817af41b>] dump_stack+0x45/0x57
[ 5354.127687]  [<ffffffff81074daa>] warn_slowpath_common+0x8a/0xc0
[ 5354.127692]  [<ffffffff81074e9a>] warn_slowpath_null+0x1a/0x20
[ 5354.127694]  [<ffffffff810f349f>] module_put+0x8f/0xa0
[ 5354.127698]  [<ffffffff810f353f>] module_unload_free+0x6f/0x120
[ 5354.127703]  [<ffffffff810f563c>] free_module+0x1bc/0x2b0
[ 5354.127706]  [<ffffffff810f5915>] SyS_delete_module+0x1e5/0x230
[ 5354.127709]  [<ffffffff817b706f>] ? int_signal+0x12/0x17
[ 5354.127711]  [<ffffffff817b6dcd>] system_call_fastpath+0x16/0x1b
[ 5354.127713] ---[ end trace 5cdc1ac3279a54f5 ]---
My system is:
pstumbler@SERVER:~$ uname -a
Linux SERVER 3.19.0-33-generic #38~14.04.1-Ubuntu SMP Fri Nov 6 18:17:28 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
pstumbler@SERVER:~$ sudo rmmod saa716x_tbs_dvb
pstumbler@SERVER:~$ lsmod | grep tbs
rc_tbs_nec             16384  0
tbs6982fe              24576  0
tbs6680fe              20480  0
tbs6923fe              24576  0
tbs6985se              20480  0
tbs6928se              20480  0
tbs6982se              24576  0
tbs6991fe              20480  0
tbs6618fe              20480  0
tbs6983fe              28672  0
tbs6922fe              24576  0
tbs6928fe              20480  0
tbs6991se              20480  0
tbs6290fe              53248  -1
rc_core                28672  8 ir_lirc_codec,ir_rc5_decoder,ir_nec_decoder,ir_sony_decoder,rc_tbs_nec,ir_mce_kbd_decoder,ir_jvc_decoder,ir_rc6_decoder
The tbs6290fe-modules shows a usage of -1...
# lspci -vvnn >> lspci_log
05:00.0 Multimedia controller [0480]: Philips Semiconductors SAA7160 [1131:7160] (rev 03)
        Subsystem: Device [6290:0001]
        Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Region 0: Memory at f7c00000 (64-bit, non-prefetchable) [size=1M]
                LnkCap: Port #1, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <4us, L1 <64us
                LnkCtl: ASPM Disabled; RCB 128 bytes Disabled- CommClk-
What can I do to prevent that?
Thanks!
pstumbler
pstumbler
Re: Kernel oops when unloading "saa716x_tbs_dvb"
Postby updatelee » Tue Nov 17, 2015 3:28 am
line 4531 of saa716x_tbs.c is calling tbs6290fe_attch directly, it should be calling dvb_attach(tbs6920fe_attach, ....
TBS does this in quite a few places actually, I dont have one of these cards so Id rather not submit a patch. You are more then welcome to try it out though. I also dont have access to the source code to tbs6920fe so I further cant really tell if there is a reason why they do it that way, there may well be.
Postby pstumbler » Wed Nov 18, 2015 2:59 am
Hi updatelee!
I changed the direct call to "dvb-attach(tbs6920fe_attach, ....)" ==> works like a charm...!
Thanks a lot!
pstumbler
pstumbler
Return to DVB-T2/T/C Dual Tuner Dual CI PCIe Card TBS6290
