TBS6909 octa + TVHEADEND freezes(solved)
Postby Abbys » Sun Nov 15, 2015 2:07 am
When I want to see three channels, Tvheadend freezes. I have to close the channels to be unlocked. Only occurs with TBS6909. DVBSky dual DVB-s works fine with five channels.
How can i fix it?
Abbys
Re: TBS6909 octa + TVHEADEND freezes
Postby Abbys » Sun Nov 15, 2015 10:16 pm
Solved!! With FTA channels is OK. Oscam problem. With last version everything is OK
thanks
Abbys
Postby aurimelis » Mon Nov 23, 2015 2:58 am
Do you use normal lnb for this card?
aurimelis
Re: TBS6909 octa + TVHEADEND freezes(solved)
Postby diabloss » Tue Dec 29, 2015 3:38 pm
Abbys
You should try out with Astra Cesbo software.
diabloss
