6290 problem cable channel
Postby gokhan2020 » Thu Nov 12, 2015 6:22 am
I have moi+pro mit 6991 se and 6290 t/t2/c
I have problem mit c tuner
always aktiv t tuner
I want search cable channels but not finden cable channels and cable tuner not aktiv
pls help
gokhan2020
Re: 6290 problem cable channel
Postby steven » Tue Nov 17, 2015 10:26 am
Hi gokhan2020
Which driver you are using ? the default one is DVB-T if you want to use DVB-C please install like this:
before step I.4 (and after I.3) from the steps in I. run:
- for x86 kernel 3.x (x86 32 bit installations of kernel 3.x):
# ./v4l/tbs-dvbc-x86_r3.sh
- for x86 kernel 2.6.x (x86 32 bit installations of kernel 2.6.x):
# ./v4l/tbs-dvbc-x86.sh
- for any x86_64 kernel (x86 64 bit installations of Linux):
# ./v4l/tbs-dvbc-x86_64.sh
Postby koho973 » Tue Jan 05, 2016 9:27 pm
Hello!!!
This solution didn't work for me.
I use Lunux Ubuntu 12.04 64-bit OS.
Please, help.
koho973
Re: 6290 problem cable channel - SOLVED!!!!!
Postby koho973 » Fri Feb 26, 2016 3:15 pm
Here is the solution kindly provided by Constantine from Turbosight
# tar xjvf linux-tbs-drivers.tar.bz2
# cd linux-tbs-drivers
# ./v4l/tbs-x86_64.sh
# make
# make install
# reboot
koho973
Return to DVB-T2/T/C Dual Tuner Dual CI PCIe Card TBS6290
