Default uboot env settings for moi?
Postby zfm2700 » Thu Nov 05, 2015 12:09 am
Hi my moi uboot environment settings appear to have corrupted. :o Can anyone give me the default uboot env settings for the moi for me to re-set? i.e. from printenv?
There doesn't appear to be a command available to reset them to default automatically. I am running in a compromised state by copying the env settings given by the reset button but would like to be in normal mode again.
Thanks!
zfm2700
Re: Default uboot env settings for moi?
Postby zfm2700 » Fri Jan 08, 2016 12:34 pm
Bump. Still need this; can't update my MOI.
zfm2700
Postby enavarrocu » Mon Mar 07, 2016 1:24 am
zfm2700 Wrote:Bump. Still need this; can't update my MOI.
bootargs=console=ttySA0,115200 mem=512M root=/dev/mtdblock3 rootfstype=yaffs2 init=/linuxrc
bootcmd=run tbscmd
mtdpart=80000 400000 3000000
bootdelay=3
baudrate=115200
ipaddr=192.168.0.20
serverip=192.168.0.10
gatewayip=192.168.0.1
netmask=255.255.255.0
tbsledcmdk1=tbs_led on
tbsledcmdk2=tbs_led off
loadmmck_bk=fatload mmc 0:1 c0008000 MOI2900_k_bk.bin
loadmmck=fatload mmc 0:1 c0008000 MOI2900_k.bin
updatek=nand erase 48c0000 400000;nand write c0008000 48c0000 400000
updatek_bk=nand erase c0000 400000;nand write c0008000 c0000 400000
loadmmcfs_bk=fatload mmc 0:1 c0008000 MOI2900_fs_bk.bin
erasefs=nand erase 50c0000
updatekfs_bk=nand erase 8c0000 4000000;nand write.yaffs c0008000 8c0000 ${filesize}
tbscmdfs=if run loadmmcfs;then run tbsledcmdk1;run updatekfs;fi
tbscmdfs_bk=if run loadmmcfs_bk;then run tbsledcmdk1;run updatekfs_bk;fi
keeprun=setenv bootargs ${bootargs} ethaddr=${ethaddr}
tbscmdk=if run loadmmck;then run tbsledcmdk1;run updatek;fi
tbscmdk_bk=if run loadmmck_bk;then run tbsledcmdk1;run updatek_bk;else run keeprun;fi
tbscmd=run tbscmdk_bk;run tbscmdfs_bk;run tbscmdk;run tbscmdfs;run tbsledcmdk2;nand read c0008000 48c0000 400000;bootm c0008000
loadmmcfs=fatload mmc 0:1 40000000 MOI2900_fs.bin
updatekfs=nand erase 50c0000;nand write.yaffs 40000000 50c0000 ${filesize}
ethaddr={MY MAC]
enavarrocu
Return to General discussion
