Windows XP Standard user No data stream
Postby ibone » Wed Nov 04, 2015 6:02 pm
I have the following system
Win XP
TBS 6893 PCIe
TBS driver 1.0.0.7
TBSdata 3.0.4.6
Run as a Standard User:
TBSdata application runs and reports 'Ensure you have installed the PME adapter controller"
System Lock is reported with good signal levels shown.
Virtual PME network is available but shows 0 bytes traffic in both directions.
Tellicast icon is red i.e. No data
Run as Admin:
TBSdata displays correct info
Tellicast icon is pink
Data is available and images available.
I have checked and the User has access to the virtual PME Netwrok devices.
I can't see any warnings or errors in the event logs to explain where there is a problem.
Bonio
ibone
Re: Windows XP Standard user No data stream
Postby steven » Wed Nov 04, 2015 6:50 pm
Please have a try uninstall TBSIPTools and using our latest TBSIPTools:
http://www.tbsdtv.com/download/document ... .0.4.9.zip
Kind regards
Postby ibone » Wed Nov 04, 2015 11:45 pm
Thanks Steven.
Can you give me the changes or is this info in the installer?
Bonio
ibone
