OpenELEC 6.0.0
OpenELEC 6.0.0
Postby vpeter » Wed Nov 04, 2015 1:13 am
vpeter
Re: OpenELEC 6.0.0
Postby steven » Wed Nov 04, 2015 3:55 pm
Hi Vpeter
Thanks for your update :)
Re: OpenELEC 6.0.0
Postby diabloss » Wed Nov 04, 2015 10:15 pm
excellent work Peter.
diabloss
Re: OpenELEC 6.0.0
Postby mikebzh44 » Fri Nov 13, 2015 1:32 am
Thanks ;)
mikebzh44
Re: OpenELEC 6.0.0
Postby Neoromancer » Fri Nov 13, 2015 8:54 pm
Thanks ;)
Neoromancer
Re: OpenELEC 6.0.0
Postby Imrisko » Sat Nov 14, 2015 3:59 pm
hey Peter, Ive installed the software. Everything runs fine but I cant swith to HDMI audio. Is this version for v1.3? Can you please help me on this!? Cheers!
Imrisko
Re: OpenELEC 6.0.0
Postby vpeter » Sat Nov 14, 2015 4:26 pm
HDMI audio works by default. If not check Kodi settings.
I was testing on v2.1 but should work on all versions.
vpeter
Re: OpenELEC 6.0.0
Postby babboy » Thu Nov 19, 2015 6:32 am
Hallo habe eine Martix V1.3 , und das einzige Openelec Image das Läuft,
ist
OpenELEC-TBS.arm-devel-20140807170606-r18774-g2c40356
bei alle anderen Friert das Bild nach dem booten ein kann mir da einer weiterhelfen
Mfg babboy
Hi have a Matrix V1.3, and the only OpenELEC Image that runs is
with all other Image Freezes after boot.
Mfg babboy
babboy
Re: OpenELEC 6.0.0
Postby vpeter » Thu Nov 19, 2015 3:27 pm
Without serial console output everything is just a guess.
vpeter
Re: OpenELEC 6.0.0
Postby babboy » Thu Nov 19, 2015 10:44 pm
How to get without rs232 Adapter
babboy
Return to Announcements
Users browsing this forum: Google [Bot] and 7 guests
