MOI+ TVheadend 4.1.0
Postby steven » Tue Nov 03, 2015 4:29 pm
Hi all
Here is the tvheadend4.1.0 for MOI+,if you want to have a try you can download it here:
tvheadend-4.1.0-moiplus.zip
tvheadend4.1.0
(4.62 MiB) Downloaded 1917 times
install way:
unzip tvheadend-4.1.0-moiplus.zip
#back
mv /usr/local/bin/tvheadend /usr/local/bin/tvheadend-back
mv /usr/local/share/tvheadend /usr/local/share/tvheadend-back
mv /usr/bin/runtvheadend.sh /usr/bin/runtvheadend.sh-back
#delete
rm -rf /.hts /root/.hts
#load
mv tvheadend /usr/local/share
mv tvheadend_bin tvheadend
mv tvheadend /usr/local/bin/tvheadend
chmod 777 /usr/local/bin/tvheadend
mv runtvheadend.sh /usr/bin
kind regards
Re: MOI+ TVheadend 4.1.0
Postby Vargas77 » Wed Nov 04, 2015 6:41 pm
great job. Thank you.
Vargas77
Postby Vargas77 » Wed Nov 11, 2015 12:31 am
can you tel me what --build (linux, OSX distribution) you'r using by cross compile.
Vargas77
Postby im85288b » Sun Nov 29, 2015 9:24 pm
I'm struggling to get this to work. In the first step where do you upload the zip file to before running the unzip command? And do you need to start tvheadend prior to the install. Thanks in advance
im85288b
Postby ForumFan » Thu Dec 17, 2015 2:35 am
After that all proces result is that I got error ERR_CONNECTION_REFUSED
I can't backup this step
#delete
Rest is set as before and same result.
The website is not available
Please Help !!!
ForumFan
Postby ronnyrock » Wed Oct 05, 2016 12:05 pm
I dont put this step
#delete
And work ok.
Regards
Ronnyrock
ronnyrock
Postby vladi2010 » Sun Oct 09, 2016 10:17 pm
hi , Does this version support Transcoding ?
regrades Andreas
vladi2010
Postby steven » Mon Oct 10, 2016 2:39 pm
Hi vladi2010
Do not support and MOI+'s CPU is not powerfull to support transcode .
Postby vladi2010 » Tue Oct 11, 2016 1:26 pm
Thankyou :-)
vladi2010
Postby mikeeps2 » Wed Apr 10, 2019 12:54 pm
anyone know if tvheadend 4.1.0 support powervu?
mikeeps2
Return to MOI+
