Tvheadend TBS 6991SE adapter problem
Postby Vargas77 » Sun Nov 01, 2015 10:02 pm
hello,
few days i'm working on tvheadend 3.9.636 (orginal with MOI+) DVBinputs advanced configuration. My dish configariotn is: switch (2 LNB 1-Circular and 2-universal ) and rotor (gotox mode nor usual). If i use DVB-input -> adapters (TBS 6991SE) -> advanced mode -> LNB Circular, Rotor gotox, Switch Generic (AA -0- A) i can't find muxes signal. Wiht other universal LBN is the same (switch AB-0-A). If change adapters mode to switch or only one LNB - all working fine.
I have tried Tvhedand 4.0.6 - but had another problem: very slow switching channels (status - subscription - state - testing (long time 1 or 2 min.))
Any suggestion?
Vargas77
Re: Tvheadend TBS 6991SE adapter problem
Postby Vargas77 » Wed Nov 04, 2015 2:58 am
Somebody has driver(firmware) for MOI+ TBS6991SE adapter: https://github.com/ljalves/linux_media/ ... stallating?
Vargas77
Postby steven » Wed Nov 04, 2015 3:59 pm
Maybe you can have a try with tvheadend 4.1.0
you can check it here :
viewtopic.php?f=164&t=9594
Kind regards
Postby Vargas77 » Wed Nov 04, 2015 6:40 pm
thank you for you answer and for your work with rvheadend (i mean 4.1.0).
When i changing channel i must wait about 2-3 minutes to see it. As i wrote, i tried tvheadend 3.6 (original), 4.0.6 and 4.1.0 but problem exist. I found on tvheadend forum about ljalves drivers for TBS adapters and i will try it (maybe this is solution). One problem is: i don't have experience with crosscompile :(
Any ideas how to solve this strange problem?
With vdr all working fine (same sat configuration).
Vargas77
Postby Vargas77 » Wed Nov 11, 2015 12:28 am
problem solved.
Vargas77
Postby costan » Sat Nov 14, 2015 6:03 am
How did you manage to solve it?
costan
Return to MOI+
