Cards (drivers) gone after centos update?(solved)
Postby pote » Sat Oct 24, 2015 9:44 am
After running yum install update all my cards are gone from tvheadend.
I suspect the kernel got updated and now the drivers for the card are not initializing anymore.
Is there a quick fix for this? Please let me know the procedure for fixing this issue?
With similar issue in Ubuntu I had to recompile and reinstall the drivers - is this the same problem here?
If so could you please provide quick instructions for the commands to fix this?
pote
Re: Cards (drivers) gone after centos update?
Postby pote » Sat Oct 24, 2015 10:50 am
So after playing around with it for a bit I figured the drivers had to be reinstalled, but also the lib files had to be removed:
Issue this command to check the cards:
dmesg | grep frontend
It should give you a heads up, on my install the tuners were first missing, but after running:
Unzip and tar the files into dir on /root
tar xj tbs... -C /root
For 64bit system urn under the /root/linux-tbs-drivers#
./v4l/tbs-x86_64.sh
./v4l/tbs-dvbc-x86_64.sh (if using dvb-c)
make
make install
Rebooting and running the dmesg|grep frontend again now I got a disagree error
uname -a to check current kernel
then delete the libs under the current kernel
rm -Rf /lib/modules/3.10.0-229.14.1.el7.x86_64/kernel/drivers/media
another reboot now running the dmesg|grep frontend shows the tuners with no errors and everything works
pote
Postby einstein74 » Sat Oct 24, 2015 12:10 pm
i have the same truble but i did the same like u and wont detect the dvb cards when i delete this rm -Rf /lib/modules/3.10.0-229.14.1.el7.x86_64/kernel/drivers/media
when i put the drivers again i get the dvb cards detect but i have error in mac address
9.223546] DVB: registering new adapter (TBS PCIE DVB Adapter)
[ 9.677180] TurboSight TBS 6904 Frontend Attaching...
[ 9.679705] TurboSight TBS6904 DVB-S2 card adapter0 MAC=ff:ff:ff:ff:ff:ff
[ 9.679716] DVB: registering adapter 12 frontend 0 (TurboSight TBS 6904 DVBS/S2 frontend)...
[ 9.680856] DVB: registering new adapter (TBS PCIE DVB Adapter)
[ 10.134214] TurboSight TBS 6904 Frontend Attaching...
[ 10.136731] TurboSight TBS6904 DVB-S2 card adapter1 MAC=ff:ff:ff:ff:ff:ff
[ 10.136742] DVB: registering adapter 13 frontend 0 (TurboSight TBS 6904 DVBS/S2 frontend)...
do u have any idea
tks
einstein74
Postby einstein74 » Sat Oct 24, 2015 12:13 pm
look i have 2 kernel diferents
/usr/lib/modules/3.10.0-229.el7.x86_64/kernel/kernel
/usr/lib/modules/3.10.0-229.14.1.el7.x86_64/kernel
someone know how to fix this?
tks
einstein74
Postby steven » Sun Oct 25, 2015 12:30 am
Hi all
After yum update it will update the kernel and the new kernel has not install our driver yet ,so
please have a try install the driver manual . if using TBS6904 with your MOIPro-AMD please using this driver first :
http://www.tbsdtv.com/download/document ... 150525.zip
Postby einstein74 » Mon Oct 26, 2015 8:05 am
yes there its working again tks
einstein74
Re: Cards (drivers) gone after centos update?(solved)
Postby kiamax » Tue Oct 27, 2015 6:29 am
after update os dvb gone and again install driver but dont see mac address and astra cant sreach
but tvheadend is ok
Please help me
kiamax
Return to MOI Pro - AMD
