TBS 6928 SE not detected by DVB software
Postby Michael » Fri Oct 23, 2015 1:58 pm
Hi all,
Since I have installed WIN10 my TBS6928SE card cannot be detected by DVB software like the DVB-viewer and TBS viewer.
Hardware manager states that everything is ok, no conflicts, newest drivers are installed.
Is this a common problem?
Thanks in advance for your help.
Regards
Michael
Michael
Re: TBS 6928 SE not detected by DVB software
Postby steven » Mon Oct 26, 2015 2:25 pm
Hi Michael
What about DVBDream or other dvbsoft is it ok? and Can you set a remote conection of your PC and send your remote connection information
to our support we will have a remote check where the problem is
Kind regards
Postby adelvesa » Tue Dec 01, 2015 7:36 pm
same problem with 6922SE on win10 x64, driver is OK, but dvb programs not find card.
adelvesa
Postby Michael » Thu Feb 18, 2016 2:57 pm
Hi again,
my problem mentioned above still exists.
Is there a solution available?
Thanks and Regards
Michael
Michael
Postby ballynafie » Sat Jul 16, 2016 5:18 pm
I have just installed Windows 10 and my 6928SE card is not being detected. Did anyone find an answer to this problem.
Many thanks
Ballynafie
ballynafie
Postby steven » Wed Jul 27, 2016 5:09 pm
ballynafie Wrote:I have just installed Windows 10 and my 6928SE card is not being detected. Did anyone find an answer to this problem.
Many thanks
Ballynafie
In your windows device manger dialog can you seee your tbs6928se device ? if not please have a try update your mainboard BIOS to latest and set the PCI-E
speed to Gen1.
stevem
