need help with moi pro
Postby root » Wed Sep 30, 2015 9:29 pm
i am trying to stream channels from fta sat galaxy 19, 97' west, with a moi pro and a tbs6991se card, everything goes well until i try to scan sat and i get these error massage , scan failed, please check sat setting and re-state again. i am trying to paste a screen shot here but not able to do it, i am new to all these but willing to try , thanks for the help
root
Re: need help with moi pro
Postby root » Fri Oct 02, 2015 11:08 pm
what should i do to get help here
root
Postby ahmedramze » Sun Oct 11, 2015 10:27 pm
what is freq and symbol rate you add , freq in KHz and symblol in Kbps you need to add 000 after for example 11747000 and 27500000
and try to connect in CLI mode telnet 192.1.xxx ip of MOI
then use dvblast or else to check the streams.
ahmedramze
Postby root » Thu Oct 15, 2015 11:38 pm
can't find CLI mode
root
Postby steven » Fri Oct 16, 2015 6:07 pm
Hi root
please contact our support#tbsdtv.com and you can set a remote connecton of your MOIPro we will help
you have a remote setting .
Postby developer » Mon Oct 19, 2015 6:05 pm
Steven,In the next firmware,add an option to update xml files for the common satellites which can be updated or filled on different screens so that most of the new users can easily test some known transponders. Sometimes we have to try different settings unlike the satellite recievers
developer
Postby steven » Mon Oct 19, 2015 6:30 pm
developer Wrote:Steven,In the next firmware,add an option to update xml files for the common satellites which can be updated or filled on different screens so that most of the new users can easily test some known transponders. Sometimes we have to try different settings unlike the satellite recievers
Hi developer
Do you mean update satellite transponder information ? :)
Kind regards
Postby root » Tue Oct 20, 2015 11:22 pm
right steven, this is most appreciated, but what are the hours, i live in Dallas Texas , and there a phone and chat line contact
root
Postby steven » Tue Oct 27, 2015 6:25 pm
Hi root
Thanks for your advice,usually which dvb soft transponder information you want to update ?tvheadend or vdr .... :)
Postby root » Fri Nov 06, 2015 6:52 am
vdr
root
Return to MOI Pro
