MatrixTV and TBS5881 - DVB-C
Postby art2d2 » Tue Sep 22, 2015 8:14 pm
Hi i have problem i install MatrixTV, but my tv tuner only show DVB-T frontend, how change it to DVB-C?
DVB: registering adapter 0 frontend 0 (TurboSight TBS 5881 DVBT/T2 frontend)... Any idea? I want use tuner with CI card for DVB-C with TVHeadEnd.
I have same thing with Ubuntu 12.04.
dmesg:
dvb-usb: found a 'TBS 5881 CI USB2.0' in cold state, will try to load a firmware
tbs5881: TBS5881 firmware init
tbs5881: start downloading TBS5881 firmware
dvb-usb: found a 'TBS 5881 CI USB2.0' in warm state.
dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
DVB: registering new adapter (TBS 5881 CI USB2.0)
dvb-usb: MAC address: 00:22:ab:b1:03:d0
tbs5881: Attached TBS5881FE!
tbs5881: CI initialized.
tbs5881: CI disabled.
input: IR-receiver inside an USB DVB receiver as /devices/platform/fsl-ehci.1/usb2/2-1/2-1.3/input/input5
dvb-usb: schedule remote query interval to 150 msecs.
dvb-usb: TBS 5881 CI USB2.0 successfully initialized and connected.
art2d2
Re: MatrixTV and TBS5881 - DVB-C
Postby vpeter » Wed Sep 23, 2015 7:25 pm
When you flash image to matrix you need to rename kernel file if I remember correctly.
vpeter
Postby art2d2 » Thu Sep 24, 2015 5:56 pm
THX :) a lot.
art2d2
Postby art2d2 » Thu Sep 24, 2015 9:30 pm
But i have a new problem -> in tvheadend
2015-09-24 15:28:31.069 mpegts: 474000 - starting for 'initscan' (weight 2)
2015-09-24 15:28:31.069 mpegts: 474000 - tuning on TurboSight TBS 5881 DVBC frontend : DVB-C #0
2015-09-24 15:28:31.070 subscription: 'initscan' subscribing to mux, weight: 2, adapter: 'TurboSight TBS 5881 DVBC frontend : DVB-C #0', network: 'Kablowka', mux: '474000'
2015-09-24 15:28:36.000 mpegts: 474000 - initial scan no data, failed
2015-09-24 15:28:36.000 subscription: "initscan" unsubscribing
art2d2
Postby matrixtv5881 » Wed Oct 28, 2015 2:08 am
I habe the same problem. Card is working on normal linux but not with the mini-pc MatrixTV. I copied dvb-usb-tbsqbox-id5881.fw from my normal linux to matrixtv as it was necessary there. dmesg | grep TBS shows then
[ 1414.363246] usb 1-2: Product: TBS 5881
[ 1414.363248] usb 1-2: Manufacturer: TBS-Tech
[ 1414.363778] dvb-usb: found a 'TBS 5881 CI USB2.0' in cold state, will try to load a firmware
[ 1414.363782] dvb-usb: downloading firmware from file 'dvb-usb-tbsqbox-id5881.fw'
[ 1414.363783] tbs5881: start downloading TBS5881 CI firmware
[ 1414.470641] dvb-usb: found a 'TBS 5881 CI USB2.0' in warm state.
[ 1414.470858] DVB: registering new adapter (TBS 5881 CI USB2.0)
[ 1416.046622] TurboSight TBS 5881 Frontend:
[ 1416.046622] tbs5881fe - software version is 2.0.0.0
[ 1416.215983] TurboSight TBS 5881 Frontend:
[ 1416.215983] tbs5881fe - Successfully Initialized
[ 1416.215993] tbs5881: Attached TBS5881FE!
[ 1416.216550] tbs5881: CI initialized.
[ 1416.216761] tbs5881: CI disabled.
[ 1416.216768] DVB: registering adapter 1 frontend 0 (TurboSight TBS 5881 DVBC frontend)...
[ 1416.217307] dvb-usb: TBS 5881 CI USB2.0 successfully initialized and connected.
[ 5492.813403] dvb-usb: TBS 5881 CI USB2.0 successfully deinitialized and disconnected.
On MatrixTV it shows
Any ideas what is wrong?
matrixtv5881
Return to Install and setup
